Date and Time Functions
This topic describes the date, time, and duration functions in Graph Studio.
Typographical Conventions
This documentation uses the following conventions in function syntax:
CAPS: Although SPARQL is case-insensitive, function names and other keywords are written in uppercase for readability.
[ argument ]: Brackets are used to indicate optional arguments. Arguments without brackets are required.
Functions
- DATE: Returns an xsd:date value based on the specified year, month, and day.
- DATEPART: Returns the date part of a literal string, date, long, or dateTime value.
- DATETIME (or xsd:dateTime): Returns a dateTime value from the given string, long, or dateTime.
- DAY: Returns the day of the month from the specified date.
- DAYSFROMDURATION: Returns the days portion of a duration value.
- DUR_TO_MILLIS: Calculates the time in milliseconds from a duration or numeric value.
- DURATION: Returns an xsd:duration value from the given numeric or duration value.
- DURATIONFORMAT: Converts a duration or numeric value to a string in the specified duration format.
- DURATIONPERIODFORMAT: Calculates the duration between the given start and end values and returns a string in the specified duration format.
- FORMATDATE: Converts a numeric or date value into a string with the specified date format.
- HOUR: Returns the hour portion of the given dateTime value.
- MASKEDDATETIME: Replaces the year, month, day, hour, minute, second, and millisecond values for the given date or dateTime value with the new date and time values that you specify.
- MILLIS: Calculates the number of milliseconds in the given date or dateTime value.
- MINUTE: Returns the minutes portion of the given dateTime value.
- MONTH: Returns the month portion of the given dateTime value.
- NOW: Returns the current server date and time.
- NOWMILLIS: Returns the current server date and time in epoch milliseconds.
- PARSEDATETIME: Attempts to convert the given string or plain literal to a date, time, or dateTime value.
- SECOND: Returns the seconds portion of the given dateTime value.
- TIME: Returns an xsd:time value based on the specified hour, minute, and second values.
- TIMEPART: Returns the time part of a time or dateTime value.
- TIMEVALUE: Converts the specified RDF term type value to an xsd:time value.
- TIMEZONE: Returns as a duration the timezone part of a dateTime value.
- TODAY: Returns today's date based on the server date.
- TZ: Returns as a string the timezone from a dateTime value.
- WEEKDAY: Returns the day of the week from a date or dateTime value.
- WEEKNUM: Returns the week of the year in which the given date or dateTime occurs.
- xsd:date: Converts the specified string, date, or dateTime value to an xsd:date.
- YEAR: Returns the year portion of the given dateTime value.
- YEARMONTH: Returns the year and month (in the format "year-month") from the specified date or dateTime value.
DATE
This function returns an xsd:date value based on the specified year, month, and day values.
DATE(year, month, day)
| year
int |
An integer that represents the year. |
| month
int |
An integer that represents the month. |
| day
int |
An integer that represents the day. |
Returns
| date |
The date according to the input values. |
DATEPART
This function returns the date part of a literal string, date, long, or dateTime value.
DATEPART(value)
| value
literal string, date, long, or dateTime |
The literal string, date, long, or dateTime value from which to return the date. |
Returns
| date |
The date part of the input values. |
This function returns a dateTime value from the given string, long, or dateTime.
DATETIME(value)
| value
string, long, dateTime |
The string, long, or dateTime value from which to return a dateTime. |
Returns
| dateTime |
The dateTime value. |
DAY
This function returns the day of the month from the specified date value.
DAY(value)
| value
date |
The date value from which to return the day of the month. |
Returns
| int |
The day of the month. |
DAYSFROMDURATION
This function returns the days portion of a duration value.
DAYSFROMDURATION(value)
| value
duration |
The duration value from which to return the days. |
Returns
| long |
The number of days in the duration. |
DUR_TO_MILLIS
This function calculates the time in milliseconds from a duration or numeric value.
DUR_TO_MILLIS(value)
| value
duration, numeric |
The duration or numeric value from which to calculate the time in milliseconds. |
Returns
| long |
The number of milliseconds. |
DURATION
This function returns an xsd:duration value from the given numeric or duration value.
DURATION(value)
| value
duration, numeric |
The duration or numeric value from which to return an xsd:duration. |
Returns
| duration |
The duration value. |
This function converts a duration or numeric value to a string in the specified duration format.
DURATIONFORMAT(value [, format ])
| value
duration, numeric |
The duration or numeric value to format. |
| format
string |
An optional value that specifies the format to use for the resulting duration string. Graph Studio supports Pattern Tokens for defining the format:- y for year digits
- M for months
- d for days
- H for hours
- m for minutes
- s for seconds
- S for milliseconds
- 'text' for arbitrary text content
If format is not specified, H:mm:ss.SSS is used. |
Returns
| string |
The duration as a string. |
This function calculates the duration between the given start and end dateTime or numeric values and returns a string in the specified duration format.
DURATIONPERIODFORMAT(start, end [, format ])
| start
dateTime, numeric |
The dateTime or numeric value that is the start of the duration period. |
| end
dateTime, numeric |
The dateTime or numeric value that is the end of the duration period. |
| format
string |
- M for months
- d for days
- H for hours
- m for minutes
- s for seconds
If format is not specified, the default is 'P'yyyy'Y'M'M'd'DT'H'H'm'M's.SSS'S'. The default value uses 'text' patterns with Pattern Tokens, which results in a string such as P1Y3M4DT1H4M44.000S. |
Returns
| string |
This function converts a numeric or date value into a string with the specified date format.
FORMATDATE(value, format)
| value
date, numeric |
The date or numeric value to convert to a string in the specified date format. |
| format
string |
The format to use for the resulting date string. Graph Studio supports Pattern Tokens for defining the format:- y for year digits
- M for months
- d for days
For example, "yyyy.MM.dd" or "dd/MM/yyyy". |
Returns
| string |
The date as a string. |
HOUR
This function returns the hour portion of the given dateTime value.
HOUR(value [, timezone ])
| value
dateTime |
The dateTime value from which to return the hour portion. |
| timezone
string |
An optional value that specifies the timezone for the value. |
Returns
MASKEDDATETIME
This function replaces the year, month, day, hour, minute, second, and millisecond values for the given date or dateTime value with the new date and time values that you specify.
MASKEDDATETIME(value, year, month, day, hour, minute, second, milliseconds)
| value
date, dateTime |
The date or dateTime for which to replace the year, month, date, hour, minute, second, and milliseconds values. |
| year
int |
The year to include in the resulting dateTime value. |
| month
int |
The month to include in the resulting dateTime value. |
| day
int |
The day to include in the resulting dateTime value. |
| hour
int |
The hour to include in the resulting dateTime value. |
| minute
int |
The minutes value to include in the resulting dateTime value. |
| second
int |
The seconds value to include in the resulting dateTime value. |
| milliseconds
int |
The milliseconds value to include in the resulting dateTime value. |
Returns
| dateTime |
The dateTime value with the specified input values. |
MILLIS
This function calculates the number of milliseconds in the given date or dateTime value.
MILLIS(value)
| value
date, dateTime |
The date or dateTime value for which to calculate the number of milliseconds. |
Returns
| long |
MINUTE
This function returns the minutes portion of the given dateTime value.
MINUTE(value)
| value
dateTime |
The dateTime value from which to return the minutes portion. |
Returns
| int |
The minutes portion of the input value. |
MONTH
This function returns the month portion of the given dateTime value.
MONTH(value)
| value
dateTime |
The dateTime value from which to return the month portion. |
Returns
NOW
This function returns the current server date and time.
NOW([ timezone ])
| timezone
string |
An optional value that specifies the timezone for which to return the current dateTime. |
Returns
| dateTime |
The current server date and time. |
NOWMILLIS
This function returns the current server date and time in epoch milliseconds.
NOWMILLIS()
Returns
| long |
The current server date and time in milliseconds. |
PARSEDATETIME
This function attempts to convert the given string or plain literal to a date, time, or dateTime value. For values that do not include a timezone, Graph Studio stores them in GMT. Values that include a timezone are stored as the appropriate value in GMT for that timezone.
PARSEDATETIME(value [, output_type ] [, format ])
| value
string, literal |
The string or plain literal value to convert to a date, time, or dateTime. |
| output_type
URI |
An optional URI (xsd:date, xsd:time, or xsd:dateTime) that specifies the type of value to return. If output_type is not specified, dateTime is returned. |
| format
string |
An optional string that species the format to use for the resulting date, time, or dateTime value. Graph Studio supports Pattern Tokens for defining the format:- y for year digits
- M for months
- d for days
- H for hours
- m for minutes
- s for seconds
For example, "yyyy.MM.dd HH:mm" or "dd/MM/yyyy HH:mm:ss". |
Returns
| date, time, or dateTime |
The conversion of the string to the desired type. |
SECOND
This function returns the seconds portion of the given dateTime value.
SECOND(value)
| value
dateTime |
The dateTime value from which to return the seconds portion. |
Returns
| int |
The seconds portion of the input value. |
TIME
This function returns an xsd:time value based on the specified hour, minute, and second values.
TIME(hour, minute, second)
| hour
int |
An integer that represents the hour. |
| minute
int |
An integer that represents the minute. |
| second
int |
An integer that represents the seconds. |
Returns
| time |
The time according to the input values. |
TIMEPART
This function returns the time part of a time or dateTime value.
TIMEPART(value)
| value
time, dateTime |
The time or dateTime value from which to return the time portion. |
Returns
| time |
The time portion of the input value. |
TIMEVALUE
This function converts the specified RDF term type value to an xsd:time value.
TIMEVALUE(value)
| value
RDF term |
The literal, URI, or blank node value to convert to a time value. |
Returns
| time |
The conversion of the term to a time value. |
TIMEZONE
This function returns the timezone part of a dateTime value as a duration. An error is returned if the input value does not include the timezone.
TIMEZONE(value)
| value
dateTime |
The dateTime value to return the timezone from. |
Returns
| duration |
The timezone in duration format. |
TODAY
This function returns today's date based on the server date.
TODAY()
Returns
| date |
Today's date according to the server. |
TZ
This function returns the timezone part of a dateTime value as a string.
TZ(value)
| value
dateTime |
Returns
| string |
The timezone as a string. |
WEEKDAY
This function returns the day of the week from a date or dateTime value.
WEEKDAY(value [, day_number_start ])
| value
date, dateTime |
The date or dateTime value from which to return the day of the week. |
| day_number_start
int |
An optional value of 1, 2, or 3 that defines how the days of the week are represented as numbers.- 1 means Sunday is day 1. Saturday is day 7.
- 2 means Monday is day 1. Sunday is day 7.
- 3 means Monday is day 0. Sunday is day 6.
If day_number_start is not specified, the default value is 1. |
Returns
| int |
The day of the week from the input values. |
WEEKNUM
This function returns the week of the year in which the given date or dateTime occurs.
WEEKNUM(value [, day_week_begins ])
| value
date, dateTime |
The date or dateTime value from which to return the week number. |
| day_week_begins
int |
An optional value of 1 or 2 that defines which day the weeks start on.- 1 means a new week starts on Sunday.
- 2 means a new week starts on Monday.
If day_week_begins is not specified, the default value is 1. |
Returns
| int |
The week of the year the input value falls in. |
xsd:date
This function converts the specified string, date, or dateTime value to an xsd:date.
xsd:date(value)
| value
string, date, dateTime |
The string, date, or dateTime value to convert to an xsd:date. |
Returns
| date |
The input values converted to dates. |
YEAR
This function returns the year portion of the given dateTime value.
YEAR(value)
| value
dateTime |
The dateTime value to return the year from. |
Returns
| int |
The year portion of the input values. |
YEARMONTH
This function returns the year and month (in the format "year-month") from the specified date or dateTime value.
YEARMONTH(value)
| value
literal date or dateTime |
The value to return the year-month from. |
Returns
| gYearMonth |
The year-month from the input values. |
