Platform Usage and Performance Monitoring
This topic provides queries that administrators can run to monitor platform usage and performance. You can run the queries from the Query Builder (See Running SPARQL Queries in the Query Builder) or against the SPARQL endpoint (See Access the SPARQL Endpoint). Each of the queries below target the System Datasource or System Tables data source, which are accessible to the sysadmin user or users with the Graph Studio Administrator role.
You can generate a cURL request against the SPARQL endpoint from a query in the Query Builder. Once you have a valid query, click the More button under the query and select Copy CURL Command.
- Return the number of queries that were run in the last N hours
- Return the average and maximum runtime of the queries run in the last N hours
- Return the number of active graphmarts
- Return the number of triples that are loaded in each active graphmart
- Return the total number of dashboards
- Return file system usage details
- Return information about the last N events
- Return a list of queries that took longer than N seconds to run
- Return the number of queries run per day
- Return the number of active users per day
- Return the number of times each user logged in during the given time period
You can run the following aggregation query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return the number of queries that were executed in the specified number of hours:
PREFIX xsd: <http://www.w3.org/2001/XMLSchema#>
PREFIX System: <http://openanzo.org/ontologies/2008/07/System#>
SELECT (COUNT(?query) as ?Nr_Of_Queries)
WHERE {
# VALUES ?hour { "N" }
# Example: in the last 5 hours
VALUES ?hour { "05" }
BIND(STRDT(CONCAT("P0Y0M0DT",?hour,"H00M00S"), xsd:duration) as ?duration)
?query a System:QueryExecution;
System:dateCreated ?time .
FILTER (?time + ?duration > NOW())
You can run the following aggregation query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return the average and maximum runtime of all of the queries that were executed in the specified number of hours:
SELECT (AVG(?queryTime) as ?avgQueryTime) (MAX(?queryTime) as ?maxQueryTime)
WHERE {
System:queryTime ?queryTime;
You can run the following query against the System Datasource (http://openanzo.org/datasource/systemDatasource) to return the number of active graphmarts, i.e., the number of graphmarts with an active query engine:
PREFIX gmart: <http://cambridgesemantics.com/ontologies/Graphmarts#>
SELECT (COUNT(?graphmart) as ?runningGraphmartCount)
WHERE {
?graphmart a gmart:Graphmart ;
# The running graphmarts are those with a query engine
gmart:graphQueryEngineUri ?o .
You can run the following query against the System Datasource (http://openanzo.org/datasource/systemDatasource) to return the number of triples that are loaded in each graphmart that is active:
PREFIX Graphmarts: <http://cambridgesemantics.com/ontologies/Graphmarts#>
PREFIX graphmartStatus: <http://cambridgesemantics.com/ontologies/GraphmartStatus#>
PREFIX dc: <http://purl.org/dc/elements/1.1/>
SELECT ?graphmart ?graphmartTitle ?statementCount
WHERE {
?graphmart dc:title ?graphmartTitle .
SERVICE <http://cambridgesemantics.com/datasource/SystemTables> {
SELECT ?graphmart ?statementCount
FROM <http://openanzo.org/namedGraphs/reserved/graphs/ALL>
WHERE {
# Get the graphmarts that are online
?graphmart a graphmartStatus:GraphmartStatus ;
graphmartStatus:status System:Online ;
# Get their triple count
graphmartStatus:totalStatements ?statementCount .
You can run the following aggregation query against the System Datasource (http://openanzo.org/datasource/systemDatasource) to return the total number of dashboards in the system:
SELECT (COUNT(?dashboard) as ?dashboardCount)
WHERE {
?dashboard a <urn:com.cambridgesemantics.application.anzoweb.lens.linkeddataset.view.GraphmartViewLens> .
FILTER(?dashboard NOT IN (<urn:com.cambridgesemantics.application.anzoweb.lens.linkeddataset.view.GraphmartViewLens>))
You can run the following query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return information about used and free space on the specified file system locations:
SELECT ?dir ?free_gb ?available_gb ?total_gb
WHERE {
?s a <http://openanzo.org/ontologies/2008/07/System#FilesystemInfo> ;
<http://openanzo.org/ontologies/2008/07/System#dirName> ?dir ;
<http://openanzo.org/ontologies/2008/07/System#fsFree> ?free ;
<http://openanzo.org/ontologies/2008/07/System#fsTotal> ?total ;
<http://openanzo.org/ontologies/2008/07/System#fsAvailable> ?available .
BIND(?free/1000000000 as ?free_gb)
BIND(?total/1000000000 as ?total_gb)
BIND(?available/1000000000 as ?available_gb)
VALUES ?dir {
# "location1"
# [ "location2" ]
# Example with / and /mnt as locations:
"/mnt"
You can run the following query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return details about the N most recent activities:
SELECT DISTINCT ?desc ?event ?user ?startTime ?completedTime ?source
WHERE {
?s a <http://openanzo.org/ontologies/2008/07/System#ActivityAuditEvent> ;
<http://purl.org/dc/elements/1.1/description> ?desc ;
<http://openanzo.org/ontologies/2008/07/System#activitySource> ?source ;
<http://openanzo.org/ontologies/2008/07/System#eventMessage> ?event ;
<http://openanzo.org/ontologies/2008/07/System#userUri> ?user ;
<http://openanzo.org/ontologies/2008/07/System#activityStarted> ?startTime ;
<http://openanzo.org/ontologies/2008/07/System#activityCompleted> ?completedTime .
# LIMIT N
LIMIT 100
You can run the following query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return a list of queries that took longer than N seconds to complete:
SELECT ?dateCreated (?queryTime/1000 as ?seconds) ?datasource
WHERE {
SELECT *
WHERE {
?queryEvent a <http://openanzo.org/ontologies/2008/07/System#QueryEvent> ;
<http://openanzo.org/ontologies/2008/07/System#queryTime> ?queryTime ;
<http://openanzo.org/ontologies/2008/07/System#dateCreated> ?dateCreated ;
<http://openanzo.org/ontologies/2008/07/System#datasourceUri> ?datasource .
FILTER(CONTAINS(STR(?queryEvent), "queryStack"))
ORDER BY DESC(?dateCreated)
LIMIT 1000
# FILTER(?queryTime > number_of_milliseconds)
# For example, 10000 milliseconds=10 seconds:
FILTER(?queryTime > 10000)
You can run the following query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return a count of the total number of queries that were run per day since the last time Graph Studio was restarted:
SELECT ?date (COUNT(?query) as ?queryPerDayCount)
WHERE {
BIND(DATEPART(?time) as ?date)
GROUP BY ?date
ORDER BY ?date
You can run the following query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return the number of active users per day since Graph Studio was last restarted:
SELECT (COUNT(DISTINCT(?user)) as ?user_count)
WHERE {
SELECT DISTINCT ?user ?date
WHERE {
?event a system:QueryEvent ;
System:userUri ?user ;
System:dateCreated ?date .
ORDER BY DESC(?date)
LIMIT 100
You can run the following query against the System Tables data source (http://cambridgesemantics.com/datasource/SystemTables) to return the number of times each user logged in between certain dates:
SELECT DISTINCT ?user (COUNT(?loginDate) as ?loginCount)
WHERE {
?s a System:UserAuditEvent ;
System:eventMessage ?eventMessage ;
System:dateCreated> ?loginDate .
FILTER(contains(?eventMessage, "Connect"))
# BIND(xsd:date("start_date") as ?startDate)
# BIND(xsd:date("end_date") as ?endDate)
# Specify the start and end dates to find the total number of logins
# between a range of time. For example, July 2023:
BIND(xsd:date("2023-07-01") as ?startDate)
BIND(xsd:date("2023-07-31") as ?endDate)
FILTER(?loginDate > ?startDate && ?loginDate < ?endDate)
GROUP BY ?user
