Setting Up GKE Workload Identity
Workload identification allows applications, services, or scripts (collectively referred to as "workloads") to authenticate and access resources residing in cloud-based platforms using short-lived, automatically managed credentials.
For instance, in Google Cloud, Workload Identity Federation allows external workloads (e.g., those running on AWS, Azure, or on-premises) to access Google Cloud resources without service account keys.
This guide walks you through setting up Workload Identity in Google Kubernetes Engine (GKE) by:
- Creating a Google Cloud IAM Service Account (GSA)
- Creating a Kubernetes Service Account (KSA)
- Binding the KSA to the GSA using the
iam.gke.io/gcp-service-accountannotation - Deploying a sample pod that uses the identity
Prerequisites
Before you begin, ensure you have the following:
- A GCP project with billing enabled
- A GKE cluster with Workload Identity enabled
- gcloud CLI installed and authenticated
- kubectl configured to access your GKE cluster
Step 1: Set variables
Set your environment variables:
export PROJECT_ID="your-gcp-project-id" export CLUSTER_NAME="your-gke-cluster-name" export CLUSTER_ZONE="your-cluster-zone" export GSA_NAME="gke-container-inspector-sa" export KSA_NAME="anzo-operator" export NAMESPACE="default"
Step 2: Create a Google Cloud Service Account (GSA)
gcloud iam service-accounts create $GSA_NAME \ --project=$PROJECT_ID \ --description="GSA for GKE Workload Identity" \ --display-name="GKE Workload Identity"
Step 3: Grant Identity and Access Management (IAM) Permissions to the GSA
Give the GSA the necessary IAM roles. For example, to access Google Cloud Storage:
gcloud projects add-iam-policy-binding $PROJECT_ID \ --member="serviceAccount:$GSA_NAME@$PROJECT_ID.iam.gserviceaccount.com" \ --role="roles/storage.objectViewer" gcloud projects add-iam-policy-binding $PROJECT_ID \ --member="serviceAccount:S$GSA_NAME@$PROJECT_ID.iam.gserviceaccount.com" \ --role="roles/artifactregistry.reader" gcloud projects add-iam-policy-binding $PROJECT_ID \ --member="serviceAccount:$GSA_NAME@$PROJECT_ID.iam.gserviceaccount.com" \ --role="roles/containeranalysis.notes.viewer"
Adjust the role as per your workload needs.
Step 4: Enable Workload Identity on the GKE Cluster
Ensure that Workload Identity is enabled on your GKE cluster. You can enable it by updating your cluster:
gcloud container clusters update $CLUSTER_NAME \ --zone $CLUSTER_ZONE \ --workload-pool="$PROJECT_ID.svc.id.goog"
This configures your cluster to use the workload pool associated with your project.
Step 5: Create a Kubernetes Service Account (KSA)
Create a KSA in your desired namespace (e.g., default):
kubectl create serviceaccount $KSA_NAME --namespace $NAMESPACE
This service account will be used by your GKE workloads (pods).
Step 6: Annotate the KSA with the GSA
To allow the KSA to impersonate the GSA, annotate the KSA with the GSA’s email:
kubectl annotate serviceaccount \ --namespace $NAMESPACE \ $KSA_NAME \ iam.gke.io/gcp-service-account=$GSA_NAME@$PROJECT_ID.iam.gserviceaccount.com
This annotation tells GKE to use the specified GCP service account when the workload uses this KSA.
