PCONTEC
Bulk Data Entry Defines Contact Electric Conductance Coefficient (CECC) for CONTACT elements in electrical analysis.
PCONTEC | PID | KCECC | KOECC | TPID | TCID |
Examples
PCONTEC | 2 | 200.0 |
PCONTEC | 2 | AUTO |
PCONTEC | 2 | 10 |
PID | Property identification
number. 1 No default (Integer > 0) |
KCECC | Contact Electric
Conductance Coefficient (CECC) for the closed contact. 2
No default |
KOECC | Contact Electric
Conductance Coefficient (CECC) for the open contact. 2 Default = 0.0 (Real ≥ 0.0) |
TPID | Identification number of a
TABLED# entry. This table specifies
conductance per unit contact area (Contact ECC) based on contact
pressure. 3, 4 Default = 0 (Integer > 0) |
TCID | Identification number of a
clearance. 3, 4, 5 Default = 0 (Integer > 0) |
- PCONTEC provides conductance per
unit area for CONTACT elements. The
PID of a PCONTEC Bulk Data Entry must
match that of an existing PCONT Bulk Data Entry.
If the secondary side is specified as grid set, a unit area is assigned to each grid in this set.
- KCECC represents contact
electrical conductance values for closed contacts. Theoretically, while higher
contact electric conductance values enforce a perfect conductor, excessively
high values may cause poor conditioning of the conductance matrix. If such
symptoms are observed, you may need to decrease the value of contact electrical
conductance.
To facilitate reasonable values for KCECC, automatic calculation (KCECC=AUTO) is supported. This determines the value of KCECC for each contact element using the contact electric conductance values of surrounding elements.
- TPID points to a TABLED# entry that specifies conductance per unit contact area (Contact ECC) based on contact pressure. Total conductance is the product of table value and actual contact area. TPID is used when Electric Contact Analysis uses STATSUB(STRUCTURE) to reference the Contact status from a static subcase. TPID overrides KCECC for coupled electric contact analysis.
- TCID points to a TABLED# entry that specifies conductance per unit contact area based on contact clearance. TPID can be specified together with TCID. When TPID is specified together with TCID, contact electrical conductance is determined from the table with TCID for open contact, and from the table with TPID for closed contact (overrides KCECC). TCID overrides KCECC for closed contact if TPID is not present.
- For clearance-based Contact ECC table lookup, Contact ECC is linearly interpolated within the table range (which should start from zero clearance), and it becomes zero when extrapolated outside the table range.
- For CONTACT interfaces without PCONT, PCONTEC is not required. Contact Electrical Conductance values based on KCECC=AUTO is utilized in such cases.
- For Electrical contact with FREEZE status, the actual contact status is considered closed in electrical conduction analysis.
- If FREEZE is set in the PCONT card, and the main and secondary side of the contact is electrically conductive, FREEZE status is automatically assigned to the contact.
- Electrical Contact Analysis via PCONTEC and PGAPEC is supported for Steady-State Electric analysis, Multi-Steady Electric analysis, and Electro-Thermal-Structure analysis.
- This card is represented as a property in HyperMesh.
