SENSOR
Bulk Data Entry Sensors may be used to activate loads.
SENSOR | SID | TYPE | STYPE | COMP | ID |
+ | LSID | GID | LBOUND/LTID | UBOUND/UTID |
+ | COND | CTYPE | LBOUND | UBOUND | |||||
+ | ACTION | ATYPE |
SENSOR | SID | TYPE | ID | ||||||
+ | ACTION | ATYPE | PTYPE | PID | FID | VALUE |
Example 1
SENSOR | 2 | TEMP | 4 | ||||||
4 | 933 | 100.0 | 200.0 |
Example 2
SENSOR | 20 | TEMP | 130 | ||||||
+ | COND | BOUND | 20.0 | 120.0 | |||||
+ | ACTION | PROP | PAFLUID | 1 | W | 0.2 |
Example 3: TYPE=FORCE, STYPE=PRETENS
SENSOR | 2 | FORCE | PRETENS | F | 23 | ||||
+ | COND | BOUND | 0.001 | ||||||
+ | ACTION | ERROR |
SID | Unique sensor
TYPE | Sensor type. No default |
STYPE | Sensor sub-type.
COMP | Component of the specified
SENSOR type. For TYPE=DISP: TX, TY, TZ, RX, RY, RZ, T, or R For TYPE=FORCE or SPCF: FX, FY, FZ, MX, MY, MZ, F, or M |
ID | Entity ID for the
specified SENSOR type. For TYPE=DISP or SPCF: Grid ID. For TYPE=FORCE: Section ID or PRETENS ID. |
Descriptions for TYPE=TEMP: | ||
ID | Grid or scalar point
identification number. No default (Integer > 0) 6 |
LSID | Load set identification
number of a QBDY1 or QVOL Bulk Data Entry. No default (Integer > 0) |
GID | Grid or scalar point
LBOUND/LTID | Lower bound of the
temperature range, or the table identification number of a
TABLEDi entry which specifies the lower bound
as a function of time. No default (Real or Integer) |
UBOUND/UTID | Upper bound of the
TABLEDi entry which specifies the upper bound
Descriptions for TYPE=DISP, SPCF, TEMP, and FORCE 3 | ||
COND | Continuation line flag indicating that condition information is to follow. | |
CTYPE | Condition type.
No default |
LB, UB | Lower and upper bounds,
which are interpreted based on the defined Condition Type
(CTYPE). No default (Real) |
ACTION | Continuation line flag indicating that action type information is to follow. | |
ATYPE | Action type. This
specifies the action performed when the above conditions are satisfied.
PTYPE |
PID | PAFLUID
property identification number. No default (Integer > 0) |
FID | Field ID. Indicates the field which will be updated. 5 | |
VALUE |
- A SENSOR with TYPE=TEMP can only be activated once. Sensor with TYPE=TEMP is supported only for Transient (linear and nonlinear) Heat Transfer analysis.
- The presence of the SENSOR Bulk Data Entry with TYPE=TEMP turns off the referenced LSID loading outside the defined temperature range and turns on the LSID loading inside the temperature range (LBOUND/LTID to UBOUND/UTID).
- SENSORs of TYPE=DISP, SPCF, and FORCE are only supported for Implicit Nonlinear Static and Implicit Nonlinear Transient analyses. Any number of conditions and actions can be specified, and the corresponding conditions and actions are appropriately combined.
- For TYPE=FORCE, a flag PRETENS can be defined to cut the solution time down significantly and terminate the run when a bolt pretension force is close to 0, that is, when thread contact is completely open. PRETENS along with continuation lines COND and ACTION can be defined as shown in Example 3: TYPE=FORCE, STYPE=PRETENS.
- PAFLUID is the only PTYPE supported. For PAFLUID, currently, FID = W only (that is, only mass flow rate update is supported). FID is updated according to the temperature BOUND provided in the COND continuation line combined with the VALUE provided in the ACTION continuation line. This can be applied in specific use cases where the mass flow rate value changes according to the temperature of the fluid.
- When TYPE = TEMP, GID refers to the grid ID that is monitored for the fluid temperature to update the mass flow rate.
- Temperature-mass flow rate feedback mechanism is supported for linear and nonlinear transient heat transfer analyses.
