CONTPRM
Bulk Data Entry Defines the default properties of all contacts and sets parameters that affect all contacts.
The default values set here can be overridden by values explicitly specified on PCONT, PCONTX, and CONTACT cards.
Note: These defaults do not apply to properties of individual gap elements that are specified on PGAP cards.
CONTPRM PARAM1 VALUE1 PARAM2 VALUE2 PARAM3 VALUE3 PARAM4 VALUE4
PARAM5 VALUE5
CONTPRM GPAD 0.5 STIFF AUTO MU1 0.3
PARAMi Parameter name.
VALi Parameter value.
Name Values SI Unit Example
ADJGRID Creates a Bulk Data file that contains contact grid SET's. The coordinates of these grids are adjusted (ADJUST), and a Bulk Data file that contains new coordinates of these contact grids after adjustment is also created. The file names are: filename_root.adjgset.fem and filename_root.adjgcrd.fem.
For N2N contact, the file names are: filename_root.n2n.adjgset.fem and filename_root.n2n.adjgcrd.fem. Additionally, the maximum adjusted distance is available in the .out file.
NO (Default)
YES
ALM Controls the activation of the augmented Lagrange multiplier (ALM) method for nonlinear contact. 9
YES
Activates the Augmented Lagrange Multiplier method for nonlinear contact.
ALMPTOL Controls the penetration tolerance and is effective when the augmented Lagrange multiplier method is activated. 10
Negative value (ALMPTOL = Real < 0.0)
Defines a scaling factor applied to an average characteristic edge length of the contact interface. The scaling factor is equal to |Real < 0.0|.
Positive value (ALMPTOL = Real > 0.0)
Defines an absolute tolerance.
See Comment 11 for default (Real < 0.0, or Real > 0.0)
ALMSFKN Controls the relative penalty stiffness of the contact interface with the augmented Lagrange multiplier method disregard of any specified STIFF options. 12
AUTO (Default)
SOFT
HARD
Negative value (ALMSFKN = Real < 0.0)
Defines a stiffness scaling factor. The stiffness scaling factor is equal to |Real < 0.0|. The scaling is applied to an automatic stiffness value (the stiffness value when SFKN=AUTO).
Positive value (ALMSFKN = Real > 0.0)
Directly prescribed stiffness.
CHKDUP Controls activation of contact duplication check.
0 (Default)
Contact duplication check is turned off.
1
Contact duplication check is turned on. A warning is issued if any of the following cases is detected for contact interfaces A and B:
  • Grids on the secondary side of contact A are all included by the secondary side of contact B, and grids on the main side of contact A are all included by the main side of contact B.
  • Grids on the secondary side of contact A are all included by the secondary side of contact B, and the main side of contact A includes all the grids on the main side of contact B.
  • Grids on the secondary side of contact A are all included by the main side of contact B, and grids on the main side of contact A are all included by the secondary side of contact B.
  • Grids on the secondary side of contact A are all included by the main side of contact B, and the main side of contact A includes all the grids on the secondary side of contact B.
CONTGAP Creates a Bulk Data file that contains internally created node-to-surface contact elements represented as CGAPG elements. The file name is: filename_root.contgap.fem. 5
NO (Default)
YES
CONTGRID Creates a Bulk Data file that contains SET's of grids involved with surface-to-surface contact elements. The file name is: filename.root.contgrid.fem.
NO (Default)
YES
CONTMPC Outputs internally created MPC's used to generate TIE contact. The MPC's are output to: <filename>_contmpc.fem.
NO (Default)
YES
CONTOUT Depending on the type of contact discretization, the following file(s) are created.
S2S discretization:
Creates a Bulk Data file that contains internally generated Surface-to-Surface Contact elements represented as PLOTEL and RBE3 elements for visualization. The file name is: <filename>.contout.fem.
N2N discretization:
Creates a Bulk Data file that contains internally generated Node-to-Node Contact elements represented as RBEAM JOINTG elements for visualization. The file name is: <filename>.n2s.fem.
NO (Default)
YES
CORIENT Indicates whether the main orientation field MORIENT on the CONTACT card applies to all surfaces or if it excludes solid elements.
ONSHELL (Default)
MORIENT applies only to contact mains that consist of shell elements or patches of grids. Main surfaces defined as faces of solid elements always push outwards, irrespective of initially open or pre-penetrating contact.
ONALL
MORIENT applies to all contact mains including, in particular, solid elements.
DEACTLIN Controls how non-FREEZE contacts are handled in linear analysis.
NONE (Default)
No contact interface is deactivated in linear analysis.
NOTFRZ
FREEZE CONTACT interfaces are deactivated in linear subcases as long as the linear subcases do not include NLSTAT pre-loading.
DISCRET Contact discretization approach for all the CONTACT/TIE entries which do not have an explicit DISCRET specification.
N2S (Default)
S2S
FRICESL Frictional elastic slip - distance of sliding up to which the frictional transverse force increases linearly with slip distance. Specified in physical distance units (similar to U0 and GPAD). Refer to Friction in the User Guide.
AUTO (Default) or Blank
Friction model based on Elastic Slip Distance, with the distance selected as 0.5% of the average characteristic edge length of all the CONTACTs.
LONG
Friction model based on Elastic Slip Distance, with the distance selected as 10% of the average characteristic edge length of all the CONTACTs.
Real > 0.0
Friction model based on Elastic Slip Distance, with the distance selected as Real > 0.0.
0.0
Friction model based on fixed transverse stiffness KT.
GPAD "Padding" of main or secondary objects to account for additional layers, such as shell thickness, and so on. This value is subtracted from contact gap opening as calculated from location of nodes. 1
THICK (Default)
NONE
(Real)
KA0TUNE Coefficient to decide the initial trial penalty for adaptive contact penalty. 8
Default = 1.0 (Real > 0.0)
KTLIN Controls the tangential stiffness KT for closed contact in linear analysis when STIFF = Real > 0.0 and MU1 = Real > 0.0 on PCONT referenced by the contact.
0 (Default)
The value of tangential stiffness KT = 0.1*STIFF. For N2S contact with CGAPG-core, the dimension of STIFF and KT is Force/Length; for N2S contact without CGAPG-core, the dimension of STIFF and KT is Force/(Length3); for S2S contact, the dimension of STIFF and KT is Force/(Length3).
1
The value of tangential stiffness KT = MU1*STIFF. The dimension of STIFF and KT is Force/(Length3).
(Integer)
LSLDCLR Indicates whether CLEARANCE is allowed for finite/continuous sliding (TRACK=FINITE/CONSLI) contact with large displacement analysis.
YES
NO (Default)
MAXPNTR Coefficient to decide the maximum allowed penetration for adaptive contact penalty. 7
Default = 0.001 (Real > 0.0)
MU1 Coefficient of static friction ( μ s) 3 4
Default = 0.0 (Real ≥ 0.0 or STICK or FREEZE)
MU2 Coefficient of kinetic friction ( μ k).
Default = MU1 (0.0 < Real < MU1)
N2SFORM Controls the core element formulation used for N2S contact.
NOCGAPG
CGAPG core is not used for N2S contact.
No default
Note: If CONTPRM,N2SFORM,NOCGAPG is not present, the CGAPG core based formulation is used when possible for N2S contact.
NONTIED Controls the output of grids which are not tied in the TIE or CONTACT (TYPE=FREEZE) interfaces.
YES (Default)
The grids which are not tied are output as a grid SET to the <filename>_nontied.fem file.
NO
The non-tied grids are not output.
PREPRT Prints initial contact conditions (except for MPC-based TIE) into an ASCII data file. The file name is: <filename>.cpr. For more information, refer to .cpr file.
NO (Default)
YES
STOP
The .cpr file is generated, and OptiStruct stops immediately.
SFPRPEN Indicates whether initial pre-penetrations are recognized and resolved in self-contact areas. (This only affects self-contact areas, wherein Main and Secondary belong to the same set or surface).
YES (Default)
Initial self-penetrations are recognized and resolved in self-contact areas. There is some danger of finding false self-penetrations across solids thinner than SRCHDIS. Refer to Resolution of Pre-penetration (CONTPRM,SFPRPEN) in the User Guide.
NO
There is no pre-penetrations to be resolved in self-contact areas, except maybe minimal intrusions due to meshing, and so on. Any self-penetrations larger than minimum element size will be ignored in those areas.
STABILIZ Controls activation of adaptive contact stabilization.
ADAPTIVE
Activates a rapid decaying contact stabilization.
If CONTPRM,STABILIZ,ADAPTIVE parameter is not present, then adaptive contact stabilization is not activated.
No default
STIFF Relative stiffness of the contact interface. 2
Positive value (STIFF = Real > 0.0) is directly specified stiffness.
Negative value (STIFF = Real < 0.0) defines a stiffness scaling factor. The stiffness scaling factor is equal to |Real < 0.0|. The scaling is applied to the automatic stiffness value (the stiffness value when STIFF = AUTO).
Default = AUTO (AUTO, SOFT, HARD, Real > 0.0, or Real < 0.0)
TIE Indicates the type of contact formulation that is used when the TIE Bulk Data Entry is present in the model.
PENALTY (Default for Implicit Analysis)
PENALTY-based formulation of the TIE contact.
MPC (Default for Explicit Analysis)
Activates the MPC-based formulation of TIE contact.
Note: Default switched automatically to PENALTY if over-constraint condition exits.
TUNESTF Controls activation of Adaptive Contact Penalty. Automatic tuning of contact penalty for implicit nonlinear analysis. 6
0 (Default)
Adaptive contact penalty is turned off.
1
Adaptive contact penalty is turned on.
  1. The initial gap opening is calculated automatically based on the relative location of secondary and main nodes (in the original, undeformed mesh). To account for additional material layers covering main or secondary objects (such as half of shell thickness), the GPAD entry can be used. GPAD option THICK automatically accounts for shell thickness on both sides of the contact interface (this also includes the effects of shell element offset ZOFFS or composite offset Z0).
  2. Option STIFF=AUTO determines the value of normal stiffness for each contact element using the stiffness of surrounding elements. Additional options SOFT and HARD create respectively softer or harder penalties. SOFT can be used in cases of convergence difficulties and HARD can be used if undesirable penetration is detected in the solution. A negative value for STIFF indicates that a stiffness scaling factor equal to |Real < 0.0| is defined. This scaling is applied on the stiffness value via STIFF=AUTO.
  3. MU1=STICK is interpreted in OptiStruct as an enforced stick condition - such contact interfaces will not enter the sliding phase. Of course, the enforced stick only applies to contacts that are closed.
  4. MU1=FREEZE enforces zero relative displacements on the contact surface - the contact gap opening remains fixed at the original value and the sliding distance is zero. The FREEZE condition applies to all secondary nodes, no matter whether their initial gap is open or closed.
  5. The file filename_root.contgap.fem, produced using the CONTGAP parameter, can be imported into HyperMesh in order to visualize internally created node-to-surface contact elements (now converted to GAPG entities).
    Note: During optimization, this file shows node-to-surface contact elements for the latest optimization iteration. In order to correctly visualize this configuration in HyperMesh for shape optimization problems, the FEA mesh shape needs to be updated by applying "Shape change" results.
    Furthermore, if GAPPRM,HMGAPST,YES is activated together with CONTPRM,CONTGAP,YES, then the gap status command file, filename_root.HM.gapstat.cmf, will also include the open/closed status of these additional GAPG's that represent node-to-surface contact elements. For correct visualization of their status in HyperMesh, file filename_root.contgap.fem needs to be imported before running the gap status command file.
  6. Adaptive contact penalty is not applicable to these cases:
    • TIE or FREEZE contact
    • Contact with nonlinear penalty
    • No-separation contact
  7. The maximum allowed penetration for adaptive contact penalty is selected as MAXPNTR*L.
    Where, L is the characteristic edge length (the average edge length on the main surface) of the contact.
  8. The initial trial penalty for adaptive contact penalty is selected as:
    • KA0TUNE*K
      Where, K is an automatically selected raw stiffness value, if STIFF=AUTO for the contact interface.
    • The contact penalty stiffness value of STIFF option, otherwise.
  9. The augmented Lagrange multiplier method is applicable to nonlinear static and transient analyses except when combined with the following features:
    • FREEZE/TIE contact
    • CGAP/CGAPG core N2S contact
    • Nonlinear penalty or the adaptive penalty method
    • The arc-length method
    For more information, refer to Augmented Lagrange Multiplier (ALM) Method (Nonlinear Analysis) in the User Guide.
  10. If the penetration of a secondary node on the main surface exceeds the specified tolerance, additional augmentation iterations will be performed. For no-separation contact, the penetration tolerance is effective for both the penetration and the opening distance once it is closed.
  11. The default penetration tolerance is defined relative to the average characteristic edge length, L, of the contact interface as follows:
    TRACK
    Tolerance
    SMALL(SMDISP)
    L*0.1%*w
    SMALL(LGDISP)
    L*1%*w
    FINITE/CONSLI
    L*5%*w
    Where, w = 1 0.1 S F K N MathType@MTEF@5@5@+= feaahqart1ev3aaatCvAUfeBSjuyZL2yd9gzLbvyNv2CaerbuLwBLn hiov2DGi1BTfMBaeXatLxBI9gBaerbd9wDYLwzYbItLDharqqtubsr 4rNCHbGeaGqiVu0Je9sqqrpepC0xbbL8F4rqqrFfpeea0xe9Lq=Jc9 vqaqpepm0xbba9pwe9Q8fs0=yqaqpepae9pg0FirpepeKkFr0xfr=x fr=xb9adbaqaaeGaciGaaiaabeqaamaabaabaaGcbaGaam4Daiabg2 da9maalaaabaGaaGymaaqaamaakaaabaGaaGimaiaac6cacaaIXaWa aqWaaeaacaWGtbGaamOraiaadUeacaWGobaacaGLhWUaayjcSdaale qaaaaaaaa@416A@ is an additional scaling factor effective for -10.0 ≤ SFKN ≤ 0.0. This scaling also applies to SFKN =AUTO or SOFT, and for SFKN≤10.0, or SFKN > 0.0, w = 1.0.
  12. The penalty stiffness employed by the augmented Lagrange multiplier method is independent of the STIFF field. Option SFKN=AUTO determines the value of the normal penalty stiffness for each contact element using the stiffness of surrounding elements along the normal direction of the surface. Additional options AUTO, HARD, SOFT or Real < 0.0 are available as a scaling factor applied on the stiffness value via SFKN=AUTO.
  13. This card is represented as a control card in HyperMesh.
