COUPLE
Subcase Information Entry Used in an implicit nonlinear subcase to convert the subcase as a coupling analysis.
COUPLE(type) = option
Argument | Option | Description |
type | <HEAT,
ELEC> No default |
The implicit nonlinear subcase is
coupled with:
option | <SUBID> No default |
- The following implicit nonlinear subcases are supported:
- Small Displacement Nonlinear Static Analysis
- Large Displacement Nonlinear Static Analysis
- Small Displacement Nonlinear Transient Analysis
- Large Displacement Nonlinear Transient Analysis
- For more information, refer to Coupling Analysis in the User Guide.
