CSTRAIN
I/O Options and Subcase Information Entry Used in the I/O Options or Subcase Information sections to request ply strain output for shell elements referencing PCOMP, PCOMPP or PCOMPG properties for all s or individual s, respectively.
Attention: Valid for Implicit and Explicit Analysis
It is also supported for solid elements referencing PCOMPLS or PSOLID with MAT9 for linear static, nonlinear static (both small and large displacement) and nonlinear transient (both small and large displacement) analysis for H3D format.
CSTRAIN (format_list,type,random,extras_list,NDIV, location, SUBSYS, NLOUT) = option
Argument Options Description
format <HM, H3D, OPTI, PUNCH, OP2, PLOT, HDF5 blank>
HM
Results are output in HyperMesh results format (.res file).
H3D
Results are output in Hyper3D format (.h3d file).
OPTI
Results are output in OptiStruct results format (.cstr file).
PUNCH
Results are output in Nastran punch results format (.pch file).
OP2
Results are output in Nastran output2 format (.op2 file) 10
PLOT
Results are output in Nastran output2 format (.op2 file) when PARAM,POST is defined in the Bulk Data section.
HDF5
Results are output in the Hierarchical Data format, Version 5 (.h5 file). 16
blank (Default)
Results are output in all active formats, for which the result is available.
type <ALL, PRINC, TENSOR, DIRECT>
Default = ALL (in DIRECT format)
ALL, blank
All strain results are output.
PRINC
Only principal strain results are output.
TENSOR
All composite strain results are output. Tensor format is used for H3D output.
DIRECT
All composite strain results are output. Direct format is used for H3D output.
random <PSDF, RMS>
No default
PSDF
Requests PSD and RMS results from Random Response Analysis to be output to the H3D file only.
RMS
Requests only the “RMS over Frequencies” result from Random Response Analysis to be output.
extras <MECH, THER>
No default
MECH
Output mechanical strain (in addition to total strain). This output is only available for H3D format.
THER
Output thermal strain (in addition to total strain). This output is only available for H3D format.
ndiv <INTEGER>
Default = 3
Number of divisions where composite strains are calculated. The maximum number of ndiv allowed in the calculation is 5. 10 - 15
location <CENTER, CORNER, blank>
CENTER (Default)
Results are available at the element center only.
CORNER
Results are available at the element corners and at the element center.
blank
Same as CENTER.
See Comment 17.
SUBSYS <SUBSYS_ID>
No default
ID of the subsystem.
When used along a subsystem definition, this option generates an individual result file for each subsystem with results for that subsystem only.
For more information, refer to the SET Bulk Data Entry.
NLOUT <NLOUT ID>
No default
ID of the NLOUT Bulk Data Entry.
For more information, refer to Comment 3 in the NLOUT Bulk Data Entry.
option <YES, ALL, blank, NO, NONE, SID, PSID>
Default = YES, ALL, blank
YES, ALL, blank
Results are output for all elements.
NO, NONE
Results are not output.
SID
If a set ID is given, results are output only for elements listed in that set.
PSID
If a property set ID is given, results for the elements referencing properties listed in the property set are output.
  1. When the CSTRAIN command is not present, ply strain results are not output.
  2. The STRAIN I/O Option controls the output of strain results for the homogenized composite material.
  3. Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
  4. Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
  5. The SOUT field on the PCOMP or PCOMPG Bulk Data Entry must be set to YES to activate strain results calculation for the corresponding ply. For PCOMPP entries, the SOUT field on the corresponding PLY entries should be set to YES.
  6. For plies defined on a PCOMPG Bulk Data Entry, the results are grouped by GPLYID.
  7. For optimization, the frequency of output to a given format is controlled by the I/O option OUTPUT.
  8. The mechanical and thermal contributions to strain may be requested in addition to the total strain.
  9. format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
  10. For shell elements, the following shows the planes where Composite Strains are calculated for different ndiv values. BOT, MID and TOP represents the bottom, middle and top planes of an individual ply. Division numbers represents the relative distance of a plane/division from the bottom of a ply. For solid elements, ndiv is always 3.
    NDIV
    Planes, where composite strains are calculated
    1
    MID
    2
    BOT, TOP
    3
    BOT, MID, TOP
    4
    BOT, 0.33, 0.67, TOP
    5
    BOT, 0.25, MID, 0.75, TOP
    Figure 1. NDIV Planes of an Individual Ply
  11. If different ndiv values are specified in CSTRESS, CSTRAIN, and CFAILURE, the largest value is used in the composite stress, strain, and failure indices calculations.
  12. When CFAILURE is not present, composite strength ratios are not output. CSTRESS and CSTRAIN entries cannot be used to request failure indices.
  13. For shell elements, the NDIV field is supported for linear static, nonlinear static (small and large displacement), normal modes, direct frequency response, modal frequency response, direct transient, modal transient and nonlinear transient (small and large displacement) analysis types only. The NDIV field is supported for first and second order elements.
  14. The NDIV field is supported for on-the-fly computation for the impl.h3d output file.
  15. For solid elements, NDIV is always equal to 3, regardless of the input.
  16. The HDF5 output is printed to a .h5 binary results file. For details of the supported analysis types and elements when the .h5 output format is requested, refer to the .h5 file.
  17. Corner results are available for linear static and nonlinear static (small and large displacement) analysis types only. These results are supported for on-the-fly and regular H3D output files.
