MCELL
Bulk Data Entry Defines the material properties for battery cell material in equivalent circuit modeling.
MCELL MID RCNUM TCFLAG
DISCHA' VOC R0 R1 C1 R2 C2
R3 C3 R4 C4 R5 C5
CHARGE' VOC R0 R1 C1 R2 C2
R3 C3 R4 C4 R5 C5
INITVP' INITVP1 INITVP2 INITVP3 INITVP4 INITVP5
MCELL 2 1 1
DISCHA 3.7 0.05 0.03 1000.0
MID Material identification number.
No default (Integer > 0)
RCNUM Indicates the number of resistor-capacitor pairs in the battery cell elements.
No default (Integer: 1, 2, 3, 4 or 5)
TCFLAG Indicates whether the material properties are defined by tables or in constant.
= 1
Ri and Ci are constant values.
= 2
Ri and Ci are from tables.
No default (Integer 1 or 2)
DISCHA Label to indicate VOC, Ri and Ci are for discharging status.
CHARGE Label to indicate VOC, R0, Ri and Ci are for charging status.
INITVP Label to indicate the following fields are for initial polarized voltage.
VOC Open circuit voltage of the battery cell.
Real > 0.0 when TCFLAG = 1.
Integer > 0 when TCFLAG = 2.
No default
R0 Internal resistance of the battery cell.
No default
Ri Resistance of the ith RC pair in the battery cell.
No default
Ci Capacitance of the ith RC pair in the battery cell.
No default
INITVP Initial polarized voltage of the ith RC pair in the battery cell.
No default
  1. The material identification number must be unique for all other material definition entries.
  2. The circuit of a BCELL element is shown as below.
    Figure 1. Details of a CELL element
  3. When TCFLAG = 2, all material properties are taken from tables. The tables define the dependency of temperature, state of charge on each field by TABLEMD.
