MPCFORCE
I/O Options and Subcase Information Entry The MPCFORCE command can be used in the I/O Options or Subcase Information sections to request multi-point force of constraint vector output for all subcases or individual subcases, respectively. For electrical analysis, MPCFORCE can be used to request multi-point charge (free charge inducted on the outer surface of a conductor).
MPCFORCE (sorting, format, form_list, peakoutput, modal, SUBSYS, NLOUT) = option
Argument | Options | Description |
sorting | <SORT1, SORT2> | This argument only applies to the PUNCH format (.pch
file) or the OUTPUT2 format (.op2
file) output for normal modes, frequency response, and
transient subcases. It will be ignored without warning if used elsewhere.
format | <OPTI, H3D,PUNCH, OP2, PLOT, blank> |
form | <REAL,
IMAG, PHASE> Default = REAL |
peakoutput | <PEAKOUT> Default = blank |
If peakout is present, only the filtered frequencies from the PEAKOUT card will be considered for this output. |
SUBSYS | <SUBSYS_ID> No default |
ID of the subsystem. When used along a subsystem definition, this option generates an individual result file for each subsystem with results for that subsystem only. For more information, refer to the SET Bulk Data Entry. |
NLOUT | <NLOUT
ID> No default |
ID of the NLOUT Bulk Data Entry. For more information, refer to Comment 3 in the NLOUT Bulk Data Entry. |
modal | <MODAL> Default = blank |
If MODAL is present, multi-point constraint forces of the structural modes and residual vectors are output to the PUNCH and OUTPUT2 files for Modal Frequency Response and Transient Analysis. |
option | <YES, ALL,
NO, NONE,
SID> Default = ALL |
- When an MPCFORCE command is not present, multi-point force of constraint vector is not output.
- Multiple formats are allowed on the same entry; these should be comma separated. If a format is not specified, this output control applies to all formats defined by the OUTPUT command, for which the result is available.
- Multiple instances of this card are allowed. If instances are conflicting, the last instance dominates.
- For optimization, the frequency of output to a given format is controlled by the I/O option OUTPUT.
- In general, HyperView does not recognize the SORT2 format for results from the .op2 file. When results are output only in SORT2 format (<Result Keyword> (SORT2, OUTPUT2, ...)), the results are written by OptiStruct into the .op2 file in SORT2 format, but when the .op2 file is imported into HyperView, the results in SORT2 format are not recognized. Therefore, the SORT1 option is recommended for results output in OUTPUT2 format and SORT2 option is recommended for results output in PUNCH format.
- format=OUTPUT2 can also be used to request results to be output in the Nastran output2 format (.op2 file).
- MPCFORCE output is available for the following
solution sequences:
- Solution Sequence
- Output Formats
- Static Analysis
- H3D, OP2, PCH, OPTI
- Normal Modes Analysis
- H3D, OP2, PCH
- Direct Frequency Response Analysis
- OP2, PCH
- Modal Frequency Response Analysis
- OP2, PCH
- Direct Transient Response Analysis
- OP2, PCH
- Modal Transient Response Analysis
- OP2, PCH
- Nonlinear Transient Response Analysis
- H3D
- Response Spectrum Analysis
- H3D, PCH
- Electrical Analysis
- H3D
