RBE2GS
Bulk Data Entry Defines a rigid element connecting two grid points which are closest to the grid point referenced by the field GS.
RBE2GS | EID | GS | TYPE | R | CM | ALPHA | |||
XS | YS | ZS | GNi | GMi |
Alternate Format
XS | YS | ZS | GNi | GMi | |||||
GMk | THRU | GMl |
RBE2GS | 19 | 8 | 2.1 | 1.2E-6 | |||||
endl | 33 | 92 |
Alternate Example
33 | THRU | 92 | endl | 23 | |||||
34 | THRU | 41 |
EID | Unique element identification
number. No default (Integer > 0) |
GS | The grid point which is to be used to
search for two nearby grids to create RBE2GS element. Default = blank (Integer > 0) |
TYPE | Type of search conducted for connecting
grids. 5
R |
CM | Components of dependent dof for grid
GM. Default = Blank (Integers 1 through 6 with no embedded blanks: Default blank is 123456) |
ALPHA | Thermal expansion coefficient. (Real or blank) |
XS, YS, ZS | Identifies the location of the search
point if the GS field is blank. Default = blank (Real) |
GNi | Grid points which are excluded from
candidate grids for GN. GNi list, if provided,
should end with endl. Default = blank (Integer > 0, THRU, or blank) |
GMi | Grid points which are excluded from
candidate grids for GM. If GNi list is not
provided, and GMj list is present, then GNi
should have an endl entry. Default = blank (Integer > 0, THRU, or blank) |
- EID field values for RBE2GS are unique with respect to all other element IDs.
- Either one of GS or XS, YS, ZS fields should be specified, otherwise, the run will print an error.
- GNi and GMj lists should end with endl in the field following the last entry in the list. All grid points are not required to exist in the range, if THRU option is used.
- Blanks are allowed for GNi and GMj lists. Also, THRU should not be the first populated entry of a continuation line.
- If GS is a structural grid
attached to part of the physical structure:
RBE2GS internally generates an RBE2 element with the same ID as the RBE2GS entry. By default, GS is chosen as GN, which is the independent grid and the closest grid within the search radius R, is chosen as GM, the dependent grid (TYPE=blank). After grids in GNi, GMj lists are excluded from the search, the grid GS is chosen as GN and GM is the closest grid within radius R from GS, in this order. If TYPE=NMFLIP, then GN, GM grids are reversed.
If GS is not a structural grid or if XS, YS, ZS is specified:
RBE2GS internally generates an RBE2 element with the same ID as the RBE2GS entry. By default, GN is the independent grid and GM is the dependent grid (TYPE=blank). After grids in GNi, GMj lists are excluded from the search, the first two grids within the radius R from GS (or XS, YS, ZS) are identified as GN and GM, in this order. If TYPE=NMFLIP, then GN, GM grids are reversed.
If TYPE=IIRBE2 or NMIIRB2:
The rules for identifying the grid points remains the same, as mentioned above, based on GS. After grid identification, the two grids chosen will be the independent GN’s of existing RBE2 elements whose independent grids lie within the search radius R. If TYPE=NMIIRB2, then GN and GM will be reversed. OptiStruct will error out, if there is just one or no RBE2 elements with independent grids in the search radius.
- PARAM, SEP1XOVR can be used to print the internally generated RBE2 elements when RBE2GS entries are present in the model. The PARAM must be set to SEP1XOVR=16. These internally generated RBE2 elements are printed in a separate <filename>.rbe2gs.fem file.
