Align to Planes
Use the Planes tool to project nodes, elements, lines and points onto a plane along a user-defined direction
  1. From the secondary ribbon, click the Planes tool.
  2. Select nodes, elements, lines, or points as source entities to be projected onto the target plane.
  3. Use the Target selector on the guide bar to select between a plane or a direction.
    • Plane - Use the Plane tool to align/project.
      The plane could be aligned to a surface/mesh/nodes, and so on.
    • Direction - Use the Vector tool to define the direction of projection. All of the selected entities are projected along the same direction.
  4. Click .
    Figure 3.
