Align to Surfaces
Use the Surfaces tool to project nodes, elements, lines and points onto a surface along either a user-defined direction or the normal to the surface selected.
From the secondary ribbon, click the Surfaces
tool.
- Select nodes, elements, lines, or points as source entities to be projected onto the target surface.
- Use the Target selector to choose the target surface.
Click
