Transitions can be bendable lines or straight lines. By default, transitions are bendable. To create straight line transitions, activate orthogonal drawing. You can also move where the transition attaches to a state element.
       To  |
       Do this  |
       Bend  |
       Click the transition. The transition is highlighted in purple. Drag the transition to bend it. You can bend transitions only when orthogonal drawing is not activated.  |
       Move  |
       Click the transition. The transition is highlighted in purple. Drag to where you want the transition to connect to the state element.  |
