Creating an NI-simulated device
You can create a virtual (or simulated) device using the NI Measurement & Automation Explorer and attach the device to an Embed diagram to modulate and display signals.
1.    Launch NI-MAX.
2.    Right-click Devices and Interfaces to Create New device.
3.    Choose Simulated NI-DAQmx Device or Modular Instrument, then click Finish.
4.    Choose a device from the NI-DAQmx Simulated Devices menu tree.
5.    Communicate with the simulated device from Embed.
a.    Start Embed and insert an NI block (Blocks > Real Time) into the work area.
b.    Right-click the block.
c.     In the dialog, select the device from the Device # dropdown. That is, select a number that corresponds to your device. Then select a Type.
d.    Click OK or press ENTER.
e.    Connect either a Signal Producer or Consumer block to the NI block and simulate the diagram.
