You can write an implicit static solver as a DLL. The following limitations apply:
•It must be named VSOLVER.DLL
•It must reside in your current directory when you initiate implicit static solving
•It must contain the exported function userSolver() that is called at each time step
To use a custom implicit static solver, activate the User Defined parameter in the Simulate > Optimization Properties dialog.
