All boards supported by Universal Library software are supported by Embed. Try to avoid using the newer USB/PCI-25xx series because they are optimized for burst mode performance. They get only about 100 Hz performance for HIL single point read/write mode.
Single-point performance of USB-1208LS is about 50 Hz, USB-1208FS is 250 Hz and USB-1208HS is 1 kHz. These figures are divided by channel count.
The USB-1608HS has eight separate ADC units and can send all channels in one USB packet, so performance of 1 kHz is not affected by channel count.
Below is the complete list of Measurement Computing boards supported by Embed.
Analog I/O |
Analog Output |
Digital I/O |
USB Boards |
PCI-DAS6071 |
PCI-DAC6702 |
PCI-CTR20HD |
USB-1208FS/LS |
PCI-6013 |
PCI-DDA02/16 |
PCI-CTR10 |
USB-1208HS-2/4A0 |
PCI-6014 |
PCI-DDA02/12 |
PCI-CTR05 |
USB-1408 |
PCI-DAS6070 |
PCIM-DDA06/16 |
PCI-DUAL-AC5 |
USB-1608G |
PCI-DAS6040 |
PCI-DDA04/16 |
PCI-DIO96H |
USB-1608LS |
PCI-DAS6025 |
PCI-DDA04/12 |
PCI-DIO96 |
USB-2533 |
PCI-DAS6023 |
PCI-DDA08/16 |
PCI-DIO48H |
USB-2537 |
PCI-DAS4020/12 |
PCI-DDA08/12 |
PCI-DIO24H |
USB-2523 |
PCI-DAS1602/12 |
PCI-DAC6703 |
PCI-DIO24/S |
USB-2527 |
PCI-DAS1200/JR |
PCI-DIO24/LP |
PCI-DAS1200 |
PCI-DIO24 |
PCI-DAS1002 |
PCI-QUAD04 |
PCI-DAS1001 |
PCI-PDISO8 |
PCI-DAS1000 |
PCI-PDISO16 |
PCI-DAS08 |
PCI-INT32 |
PCIM-DAS16JR/16 |
PCIM-DAS1602/16 |
PCI-DAS6402/16 |
PCI-DAS64/M2/16 |
PCI-DAS64/M1/16 |
PCI-DAS6052 |
PCI-DAS6036 |
PCI-DAS6035 |
PCI-DAS6034 |
PCI-DAS6033 |
PCI-DAS6032 |
PCI-DAS6031 |
PCI-DAS6030 |
PCI-DAS6014 |
PCI-DAS6013 |
PCI-DAS1602/16 |
PCI-DAS-TC/BRD |
