You can communicate and exchange data with devices outside the Embed environment in the following ways:
•Interface with a USB Controller Area Network (CAN) device to read and write CAN messages on the CAN bus
•Connect to any OPC server and log data or run a virtual plant in Embed for offline tuning
•Perform real-time data acquisition and signal generation using National Instruments and Measurement Computing I/O cards, PLCs, and DCSs
•Perform serial I/O with other computers
•Exchange data over the Ethernet using UDP
