The primary function of the proportional-integral (PI) compensator is to increase the low frequency gains to reduce steady-state errors and decrease sensitivity to noise and parameter variations.
Transfer function
Bode plots
To design a PI compensator
Because the function of the PI compensator is to increase low frequency gain, the design steps differ from the Lead and PD compensators.
1. Determine the frequency (ω*) that defines the region ω < ω* in which the gain is to be increased.
2. Determine the amount of gain to be added (K*) using the error coefficient specifications for the system.
3.
Identify the crossover frequency and phase margin from the uncompensated system
Bode plots,
and
4.
Select the zero of the PI compensator to satisfy the steady-state error
specifications. If, however, a phase margin problem exists (for example, the
phase margin is less than 30 degrees), do not allow it to move past
5. Initially select K = 1 and tune the compensator slightly by modifying the value of K for the desired performance.
