If you want to share a DLL with other users:
•Use Embed’s File > Send command if the recipients also need the diagram that uses the DLL. File > Send automatically attaches the current diagram to the email; however, you must manually attach the DLL.
•Use your email program to attach and send just the DLL.
In the email, tell the recipient to save the attachments, then register the DLL with Embed by either:
•Using Embed’s Edit > Preferences > Addons command.
•Saving the DLL to the same directory as the corresponding diagram or to any directory that Windows searches, including the system PATH variable.
