You can alternatively start Embed with command line arguments in a Command window. Starting Embed this way provides these capabilities:
•You can invoke Embed from another application
•You can run Embed in the background
To start Embed from a Command window prompt
1. Start a Command window.
2. Navigate to the Embed install directory.
3. Start Embed by entering one of the following commands:
Embed-install-directory vissim32 –arg1 -arg2 -arg3… [path-to-block-diagram.vsm]
Embed-install-directory vissim64 –arg1 -arg2 -arg3… [path-to-block-diagram.vsm]
If you enter more than one argument, separate them with spaces. If a diagram name is included in the argument list, it must be specified last.
