DMGEVO
Bulk Data Entry Defines the damage evolution.
| DMGEVO | DMGEVOID | TYPE | SHAPE | FLAT | |||||
| MMXFM | ALPHA | W1 | W2 | W3 | X1 | ||||
| ALPHA_2 | W1_2 | W2_2 | W3_2 | X2 | |||||
Example (Damage based on energy with power law mixing)
| DMGEVO | 24 | COHENRG | EXP | ||||||
| 1 | 1.2 | 2.0 | 5.0 | 5.0 |
Example (Damage based on energy with B-K form mixing)
| DMGEVO | 57 | COHENRG | LIN | ||||||
| 2 | 1.5 | 24.0 | 50.0 |
Example (Damage based on energy no mode mixing)
| 20.0 |
Example (Damage based on opening)
| DMGEVO | 1 | COHDISP | EXP | ||||||
| 2.0 | 20.0 |
Example (Ductile damage based on displacement)
| DMGEVO | 1 | DISP | EXP | ||||||
| 2.0 | 0.5 |
Example (Ductile damage based on energy)
| DMGEVO | 1 | ENERGY | LIN | ||||||
| 20.0 |
| DMGEVOID | Damage evolution
| TYPE | Damage evolution type.
No default |
| SHAPE | Profile shape of the
traction-opening curve in the descending part.
| FLAT |
Specifies the handling method for y-values outside the
specified range of x-values.
| MMXFM | Mode mixed form (only
for TYPE = COHENRG).
| ALPHA | When
TYPE = COHDISP with
SHAPE = EXP, it is the
exponent for the traction-separation curve. When TYPE = COHENRG with MMXFM = 1, it is the exponent for the mixing formula. When TYPE = COHENRG with MMXFM = 2, it is the mixing coefficient. When TYPE = DISP with SHAPE = EXP, it is the exponent for the stress degrading curve. When ENERGY with shape = EXP, it is the exponent for the stress degrading curve. No default (Real > 0) |
| W1. W2, W3 | Material curve
parameters. When
TYPE=COHDISP/DISP,
only W1 is required.
When
TYPE=COHENRG, the
parameters are the energies that can be dissipated in pure
normal and pure shear separation.
When
TYPE=COHENRG with
MMXFM= Blank.
When
TYPE=DISP
When
TYPE=ENERGY
Unit of length for
TYPE=COHDISP/DISP Force/Length or Energy/Length2 for TYPE=COHENRG/ENERGY |
| ALPHA_i, W1_i, W2_i, W3_i | The
ALPHA, W1,
W2 and W3 values
corresponding to temperature Xi. No default (Real > 0) |
| Xi | Temperature
values. If the damage constants are temperature independent, X1 can be blank. No default (Real) |
- The material identification number should be unique for all MAT1, MAT2, MAT3, MAT8, MAT9, MGASK, MCOHE, MCOHED, DMGINI, and DMGEVO entries.
- The support information for damage
evolution is:
Analysis Types Criterion Nonlinear Static Analysis, Nonlinear Transient Analysis DISP, ENERGY, COHDISP, COHENRG Explicit Dynamic Analysis DISP, ENERGY Element Types Criterion Regular Shell and Solid Elements DISP, ENERGY Cohesive Elements COHDISP, COHENRG - Characteristic length is calculated element by element in ductile damage analysis. It is related to element size.
- For additional information about cohesive elements, refer to Cohesive Zone Modeling in the User Guide.
