EIGC
Bulk Data Entry Defines data required to perform complex eigenvalue analysis.
| EIGC | SID | NORM | G | C | ND0 |
| ALPHAAJ | OMEGAAJ | ND1 | |||||||
| EXTN | UB |
Example 1
| EIGC | 4 | MAX | 15 |
Example 2
| EIGC | 4 | MAX | |||||||
| 15 |
Example 3
| 1000.0 | 1000.0 | 15 |
| SID | Unique set identification number. No default (Integer > 0) |
| NORM | Indicates the option for normalizing
eigenvectors.
| G | Grid
or scalar point identification number. Required
only if NORM =
POINT. No default (Integer > 0) |
| C | Component number. Required only if
NORM = POINT
and G is a geometric grid
point. No default (0 ≤ Integer ≤ 6) |
| ND0 | Desired number of roots and eigenvectors to be
extracted. Required if there is no continuation, and it must be empty if the ALPHAAJ continuation line exists. Default = blank (Integer > 0) |
| ND1 | Desired number of roots and eigenvectors to be
extracted. No default (Integer > 0) |
| ALPHAAJ | Real
part of the shift point. Default = 0.0 (Real) |
| OMEGAAJ | Imaginary part of the shift point. Default = 0.0 (Real) |
| EXTN | Flag indicating that parameters for EIGC entry are to follow. | |
| UB | Upper bound of the frequency up to which Complex
Eigenvalue pairs will be output. This option only
affects the output and not the analysis. 3 Default = blank (Real) |
- ALPHAAJ and OMEGAAJ are only useful for direct complex eigenvalue analysis. If there is no METHOD command present in the subcase control area, the direct method is considered for the complex eigenvalue analysis. Otherwise, modal method is used.
- The third field is reserved for a numerical complex eigensolution (METHOD). Currently, this field should be left blank; however, certain method types (INV, HESS and CLAN) will be accepted, but there will be no effect on the analysis.
- For modal complex eigenvalue analysis, set the ND0 field to AUTO.
