HARMONICS
I/O Options EntryUsed to specify the solution harmonics to be used in cyclic symmetry analysis.
HARMONICS = option
Example 1
Using SET definition in the Bulk Data
section.
HARMONICS = 26
SET, 26, MODE
+, 0, 1, 2, 6, 10Example 2
Using SET definition in the Case Control
section.
HARMONICS = 26
SET 26 = 0, 1, 2, 6, 10Definitions
| Argument | Options | Description |
| option | <ALL, SETID> |
(Integer > 0) |
- When the HARMONICS I/O Option is not present, HARMONICS=ALL will be set by default in cyclic symmetry analysis.
- The SET definition referenced by HARMONICS should be a set of TYPE = MODE.
- The harmonic indices are supposed to be non-negative and must be no
greater than (NSEG is defined in the CYSYM Bulk Data Entry).
If NSEG is odd:
If NSEG is even:
- Further remarks regarding different harmonic options for different
subcase types are summarized in the table.
Subcase Type Non-cyclic Symmetric Behavior Cyclic Symmetric Behaviour* Linear Static - Cyclic symmetry analysis can solve for non-cyclic symmetric deformation if non-cyclic symmetric loadings (including non-cyclic symmetric SPCD) exist in the input file.
- The result is a linear superposition of all the requested harmonic solutions.
- When all the necessary harmonics are requested, cyclic symmetry linear static analysis is capable of generating deformation identical to a regular linear static analysis which has all the segments of the structure being modelled; therefore, HARMONICS=ALL is usually recommended. In general, harmonics with lower indices contribute more to the result of in a linear static cyclic symmetry analysis, and removing some harmonics may lead to loss in accuracy.
- If there is no non-cyclic symmetric loading (including non-cyclic symmetric SPCD), all the harmonics vanish except the 0th harmonic, which leads to cyclic symmetric deformation.
Normal Mode - Each harmonic solves for a series of modal shapes of a certain pattern and the result is a collection of modes calculated from the requested harmonic solutions.
- When all the necessary harmonics are requested, cyclic symmetry normal mode analysis is capable of generating a same number of modes identical to a regular normal mode analysis which has all the segments of the structure being modelled.
- Removing a certain harmonic index h from the set referenced by HARMONICS would result in the absence in the corresponding mode shapes with h nodal diameters.
- The 0th harmonic corresponds to mode shapes with cyclic symmetric mode shapes, that is, no nodal diameter.
Nonlinear Static, Nonlinear Transient N/A - Only the 0th harmonic (as in, completely cyclic symmetric behaviour) is allowed due to theoretical restrictions.
Preloading/Preloaded Subcase in Prestressed Analyses - Subsequent preloaded subcase can have non-cyclic symmetric deformation or modes.
- Preloading must be completely cyclic symmetric due to theoretical restrictions.
