MATHF
Bulk Data Entry Defines the material properties in a one-step stamping simulation.
| MATHF | MID | E | NU | Y | K | n | EPS0 | ||
| R0 | R45 | R90 | TABLEID |
| MATHF | 17 | 21.0E4 | 0.3 | 184.297 | 549.03 | 0.22 | 0.007 | ||
| 1.6 | 1.6 | 1.6 |
| MID | Unique material
| E | Young's Modulus. No default (Real) |
| NU | Poisson's ratio. Default = blank (-1.0 < Real < 0.5 or blank) |
| Y | Yield stress. No default (Real) |
| K | Strength coefficient. No default (Real or blank) |
| n | Strain hardening
component. No default (Real or blank) |
| EPS0 | Pre-strain
| R0, R45, R90 | Lankford
coefficients. No default (Real) |
| TABLEID | Table ID for stress-strain
curve using a TABLES1
entry. No default (Integer > 0) |
- This entry is only valid with a @ HyperForm statement in the first line of the input file.
- The TABLEID and the corresponding curve are required only when material data is specified with a stress-strain curve. For such case, material parameter such as K, n and EPS0 are extracted from the stress strain curve.
