OFREQUENCY
I/O Options and Subcase Information Entry The OFREQUENCY command can be used in the I/O Options or Subcase Information sections to request a set of frequencies for output requests for all subcases or individual subcases, respectively.
OFREQUENCY = option
| Argument | Options | Description |
| option | <ALL, SID> Default = ALL |
- When OFREQUENCY is not present, output is for all frequencies.
- The SET definition referenced by the OFREQUENCY card must be a real value set.
- The number of solutions selected will always be equal to the number of quantities in the selected set. The closest values will be used.
