I/O Options EntryThe OUTPUT command can be used to
control the format of results output and the creation of certain results files.
OUTPUT, keyword, frequency,
option1, option2,
option3
| Argument |
Options |
Description |
| keyword |
See below |
See below |
| frequency |
FIRST,
LAST, FL, ALL, NONE,
N, CONV,
CURRENT, or blank |
- FIRST
- Output first iteration only.
- LAST
- Output last iteration only.
- FL
- Output first and last iterations.
- ALL
- Output all iterations.
- NONE
- No output.
- N
- Outputs the first and last iterations and every Nth
iteration.
- If N=5, output occurs at iterations 0,
5, 10, 15, 20, and so on, and the final iteration.
- CONV
- Outputs the first and all subsequent converged
iterations during Topology Optimization.
- CURRENT
- A separate <filename>_cur.h3d
file is generated for optimization runs. This file
consists of analysis run output for the current
optimization iteration. This file is overwritten for
each subsequent optimization iteration.
Note: This option
only applies to optimization runs with
H3D keyword and
BYITER option. OptiStruct will error out if
CURRENT frequency is used with
BYSUB/blank option.
- blank
- The default listed below for the given keyword.
| option |
See below |
See below |
