PARAM, AXCYSYM
Bulk Data Entry Allows definition of a user-specified axis of symmetry, in cyclic symmetry analysis.
| Parameter | Values | Description |
| AXCYSYM | <YES, NO> |
- If the CYAX entry is not present in the input, PARAM, AXCYSYM, YES is not effective.
- When PARAM, AXCYSYM, YES is specified, the restrictions for grids on CYAX Bulk Data Entry still apply. That is, the grids on CYAX should lie on the axis of symmetry, the coordinate system referenced by the grid CD fields should be rectangular and their Z-axes should point in the positive direction of the axis of symmetry. Refer to the CYAX entry for more details.
- If PARAM, AXCYSYM, YES is specified, the restrictions for the CD fields of grids on CYJOIN no longer apply. Refer to the Comments in the CYJOIN entry for more details.
