PRETENS
Bulk Data Entry Defines 1D or 3D pre-tensioned bolt section.
| PRETENS | SID | EID | SURFID | NTYP | G1/X1/ CID | G2 / X2 | G3 / X3 | SPNTID |
Examples
| PRETENS | 2 | 5 |
| PRETENS | 3 | 4 |
| SID | Unique section identification number. | |
| EID | Element identification
number of a bar, beam or rod element for defining 1D
pre-tensioned bolt. (Integer > 0 for 1D pre-tensioned bolt, or blank for 3D pre-tensioned bolt) |
| SURFID | Identifier of
SURF card which defines cutting section
of 3D pre-tensioned bolt. (Integer > 0 for 3D pre-tensioned bolt, or blank for 1D pre-tensioned bolt) 2 |
| NTYP | Type of determination
of normal to the pretension section. 3
| G1, G2, G3 | Three grid identifiers
that define the plane where it's normal is the direction of the
bolt. Default = blank (Integer > 0). When requested, all three nodes must be specified. |
| X1, X2, X3 | Coordinates, in basic
system, of the vector that defines direction of
pretension. Default = blank (Real). The length of the vector must be non-zero. |
| CID | Identifier of a
coordinate system that defines direction of pretension. For rectangular system, the local x-axis defines the pretension direction. For cylindrical and spherical systems, the local z-axis defines the pretension direction. Default = blank (Integer > 0). |
| SPNTID | SPOINT that defines the DOF containing
the pretension deformation and load. Default is not to output the pretension deformation in results files. |
- Each 1D pretension section defines only one element.
- A surface defined by SURFID should be constructed by solid elements on the same side of the surface.
- The default direction of pretension is
defined automatically from the configuration of the pretension section.
- For 1D elements, it is along the axis of the respective 1D element.
- For 3D pretension, it is defined as the average normal to the respective SURFace (average of respective element normals).
