SPC1
Bulk Data Entry Defines sets of single-point constraints and thermal boundary conditions.
| SPC1 | SID | C | G1 | G2 | G3 | G4 | G5 | G6 | |
| G7 | G8 | G9 | etc. |
Alternate Format
| SPC1 | SID | C | G1 | "thru" | G2 |
| SPC1 | 3 | 2 | 7 | 3 | 10 | 9 | 6 | 5 | |
| THRU | 8 | 33 | 71 | ||||||
| SPC1 | 2 | 2 | 87 | "thru" | 100 |
| SID | Single-point constraint
set identification number. (Integer > 0) |
| C | Component
number. (Integer zero or blank for scalar points, or up to six unique digits (0 < digit ≤ 6) may be placed in the field with no embedded blanks for grid points. The components refer to the coordinate system referenced by the grid points.) |
| Gi | Grid or scalar point
identification numbers. (Integer > 0) |
- The degree-of-freedom declared dependent on this entry may not be:
- Enforced displacements are not available via this entry.
- Any number of continuations may appear.
- Multiple "thru" sequences can be used on a single card, and can span across continuation lines.
- SPC degrees-of-freedom may be redundantly specified as permanent constraints on the GRID entry.
- If the "thru" comment is used, G1 and G2 must exist, but the grid points between G1 and G2 are not required to exist.
- For static and dynamic analyses, when the SPSYNTAX setting on the SYSSETTING I/O Option is set to CHECK (default) or MIXED, it is allowed that when grid lists are provided for a given component, that the grid references be either scalar points (SPOINT) or structural grid points (GRID) when the component is 0, 1 or blank; interpreting all of these as 0 for scalar points and as 1 for structural grids. When SPSYNTAX is set to STRICT, it is required for grid/component pairs (G#/C#) that the component be 0 or blank when the grid references are to scalar points (SPOINT), and that the component be ≥ 1 when the grid references are to structural grid points (GRID). When the component is greater than 1, the grid references must always be a structural grid (GRID).
- For linear steady-state heat transfer analysis, SPC1 may be used to define temperature boundary conditions; however, unless paired with an SPCD entry, the enforced temperature is 0.0. For thermal boundary conditions, the component should be 0 or blank when the SPSYNTAX setting on the SYSSETTING I/O Option is set to CHECK (default) or STRICT. When SPSYNTAX is set to MIXED, 1 is also accepted as the component.
- This card is represented as a constraint load in HyperMesh.
