AECOMPL
Bulk Data Entry Defines a component for use in monitoring point definition or external splines.
| AECOMPL | NAME | LABEL1 | LABEL2 | LABEL3 | LABEL4 | LABEL5 | LABEL6 | LABEL7 | |
| LABEL8 | etc. |
| AECOMPL | WING1 | CSURF | FLAP |
| NAME | Character string to identify the component. (Character; up to 8 characters) |
| LABELi | Names of components defined by other
AECOMP or AECOMPL
entries. (Character; up to 8 characters) |
- The NAME field should be unique among all AECOMP and AECOMPL entries.
- The AECOMPL entry can be used to combine AECOMP entries into new components. When combining components, the structural and aerodynamic mesh-based components should always be separate.
