APRESSURE
I/O Options and Subcase Information Entry Used to request aerodynamic pressures in static aeroelastic response.
APRESSURE = option
| Argument | Options | Description |
| option | <ALL, NO, SID> Default = ALL |
- This command is supported only for Aeroelastic Static Analysis.
- The SET command references box identification numbers.
- When option is set toALL, only pressures on all boxes are output because aerodynamic pressure is only available for lifting boxes.
- The output is printed in the .trim ASCII file.
