BMFACE
Bulk Data Entry Defines quad or tria faces that are in turn used to define a barrier to limit the total deformation for free-shape design regions.
| BMFACE | BMID | G1 | G2 | G3 | G4 |
| BMFACE | 10 | 8203 | 8204 | 8100 |
| BMID | Barrier mesh
identification number. Referenced from a DSHAPE Bulk Data Entry. No default (Integer > 0) |
| G# | Grid point identification
number of connection points. G1,
G2, and G3 are required to
define tria faces, G4 is required to define quad
faces. No default (Integer ≥ 0, all unique) |
- Grid points used in the definition of BMFACE entries cannot be used to define structural elements.
