CDSMETH
I/O Options and Subcase Information Entry The CDSMETH command can be used in component dynamic synthesis method for generating component dynamic matrices at each loading frequency.
CDSMETH = CDSID
CDSMETH = 10
| Argument | Options | Description |
| CDSID | <INTEGER> Default = NONE |
ID of CDSMETH in the Bulk Data section. |
- If CDSMETH is specified, only one is allowed. The data corresponding to component dynamic synthesis will be stored in an H3D file with the name filename_CDS.h3d.
- The must be a modal frequency response , except it does not require a DLOAD card for load specification.
