CELAS2
Bulk Data Entry Defines a scalar spring element of the structural model without reference to a property entry.
| CELAS2 | EID | K | G1 | C | G2 | C | GE | S |
| CELAS2 | 28 | 6.2+3 | 19 | 4 |
| EID | Unique element
| K | Spring stiffness. No default (Real) |
| G1, G2 | Geometric grid point or
scalar point identification number. Default = 0 (Integer ≥ 0) |
| C, C | Component number in the
displacement coordinate system specified by the
CD entry of the GRID
data. Default = 0 (0 ≤ Integer ≤ 6) |
| GE | Damping
coefficient. GE is ignored in Transient Analysis, if PARAM, W4 is not specified. Default = 0.0 (Real) |
| S | Stress
coefficient. Default = 0.0 (Real) |
- Zero or blank may be used to indicate a grounded terminal G1 or G2 with a corresponding blank or zero C or C. A grounded terminal is a point whose displacement is constrained to zero.
- Scalar points may be used for G1 and/or G2 (with a corresponding C and/or C of zero or blank). If only scalar points and/or grounded terminals are involved, it is more efficient to use the CELAS4 entry.
- This single entry completely defines the element since no material or geometric properties are required.
- The two connection points (G1, C) and (G2, C) must be distinct.
- To obtain the damping coefficient GE, multiply the critical damping ratio, by 2.
- A scalar point specified on this entry does not need to be defined on a SPOINT Bulk Data Entry.
The element force of a spring is calculated from the equation:
Where, is the stiffness coefficient for the scalar element, is the displacement of the first degree-of-freedom listed on the CELAS1 and CELAS2 entries and is the displacement of the second degree-of-freedom listed on the CELAS1 and CELAS2 entries.Element stresses are calculated from the equation:
Where, is the stress coefficient as defined above. - When the SPSYNTAX setting on the SYSSETTING I/O Options Entry is set to CHECK (default) or STRICT, it is required for grid/component pairs (G#/C#) that the component be 0 or blank when the grid reference is a scalar point (SPOINT), and that the component be > 1 when the grid reference is a structural grid point (GRID). When SPSYNTAX is set to MIXED, it is allowed for grid/component pairs (G#/C#) that the grid reference be either a scalar point (SPOINT) or a structural grid point (GRID) when the component is 0, 1 or blank; interpreting all of these as 0 for scalar points and as 1 for structural grids. When the component is greater than 1, the grid reference must always be a structural grid (GRID).
- A CBUSH element, referencing a PBUSH property with a single stiffness term, is equivalent to a CELAS1 or CELAS2 element, only when the elements have zero length. A non-zero length CBUSH assumes rigid body connections from the connection points, GA and GB, to the spring-damper location, as defined either by S or the OCID and Si fields.
- This card is represented as a spring or mass element in HyperMesh.
