CHGAREA
Bulk Data Entry Defines the charge density on faces of CHEXA, CPENTA, CTETRA, or CPYRA solid elements.
| CHGAREA | SID | EID | Q1 | Q2 | Q3 | Q4 | G1 | G2 or G3 |
| CHGAREA | 2 | 1106 | 10.0 | 8.0 | 5.0 | 1.0 | 1 | 48 |
| SID | Load identification
number. (Integer > 0) |
| EID | Element identification
| Q1, Q2, Q3, Q4 | Charge density per unit
surface area at the corners of the face of the element.
(Real) |
| G1 | Identification number of a
grid point connected to a corner of the face. For
CPYRA elements, this grid must be on an edge
of the quadrilateral face. (Integer > 0) |
| G2 | Identification number of a
grid point connected to a corner diagonally opposite to
G1 on the same face of a
CHEXA or CPENTA element.
(Integer or blank) |
| G3 | TETRA grid identification number located at the corner not on the face being loaded. This is required data and is used for TETRA elements only. |
- Equivalent grid charge densities are computed by linear (or bi-linear) interpolation of load intensity, followed by numerical integration using isoperimetrical shape functions. Uniform load intensity does not necessarily result in equal equivalent grid point loads.
- For the triangular faces of PENTA elements, G1 is an identification number of a corner grid point that is on the face being loaded and the G3 or G4 field is left blank. For faces of TETRA elements, G1 is an identification number of a corner grid point that is on the face being loaded and G4 is an identification number of the corner grid point that is not on the face being loaded. Since a TETRA has only four corner points, this point, G4, is unique and different for each of the four faces of a TETRA element.
- For the quadrilateral face of the PYRA element, G1 is an identification number of a corner grid point on the face and the G3 or G4 field is left blank. For triangular faces, G1 and G3 must specify the grids on the edge of the face that borders the quadrilateral face, and the grids must be ordered so that they define an inward normal using the right-hand rule.
- For more information, refer to Piezoelectric Analysis in the User Guide.
