CMSMETH
Subcase Information Entry The CMSMETH command can be used to request that only a component mode synthesis solution be performed and to select a component mode synthesis method definition to be used.
CMSMETH = option
| Argument | Options | Description |
| option | <CMSID> No default |
- All subcases must have the same MPC reference; in which case it runs the component mode synthesis (flexible-body preparation) solution sequence using the CMSMETH reference and the common MPC reference.
