CMSPDP
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence.
| CMSPDP | EID | K | G1 | G2 | B | L | PF | TYPE |
| CMSPDP | 3 | 34.5 | 223 | 324 | 0.0 | 1.0 | TRANS |
| EID | Unique element
identification number. (Integer > 0) |
| K | Stiffness value. Default = 0.0 (Real or blank) |
| G1, G2 | Grid point identification
| B | Damping value. Default = 0.0 (Real or blank) |
| L | Unstretched length/angle
of spring damper. 3 Default = 0 (Real ≥ 0.0 or blank) |
| PF | Preload force. Default = 0 (Real or blank) |
| TYPE | Type.
- The spring damper force is along the line segment connecting the grids G1 and G2.
- The positive preload force is a stretching force.
- If the unstretched length/angle of spring
damper field (L) is blank:
- For a translational spring, OptiStruct calculates the length between the two grid points (G1, G2) of the spring damper for the value of L.
- For a rotational spring, L is set to 0.0.
- This card is represented as a spring element in HyperMesh.
