CMSPDPT
Bulk Data Entry Defines a spring damper element without reference to a property entry for multibody solution sequence.
| CMSPDPT | EID | KTID | G1 | G2 | BTID | L | PF | TYPE |
| CMSPDPT | 3 | 3 | 223 | 324 | 4 | 1.0 | TRANS |
| EID | Unique element
identification number. (Integer > 0) |
| KTID | TABLEDi
ID for stiffness. Default = 0 (Integer ≥ 0 or blank) |
| G1, G2 | Grid point identification
| BTID | TABLEDi
ID for damping. Default = 0 (Integer ≥ 0 or blank) |
| L | Unstretched length of
spring damper. Default = 0 (Real > 0.0 or blank) |
| PF | Preload force. Default = 0 (Real or blank) |
| TYPE | Type.
- The spring damper force is along the line segment connecting the grids G1 and G2.
- The positive preload force is a stretching force.
- This card is represented as a spring element in HyperMesh.
