DIVERG
Bulk Data Entry Specifies the number of Divergence pressures and Mach numbers for a static aeroelastic divergence analysis.
| DIVERG | SID | NROOT | M1 | M2 | M3 | M4 | M5 | M6 | |
| M7 | M8 | etc. |
| DIVERG | 34 | 8 | 0.6 | 0.7 | 0.8 |
Definition
| SID | Divergence Mach number set identification number. 1
2 No default (Integer > 0) |
| NROOT | Maximum number of Divergence pressures. If there is no
divergence, then no divergence pressures will be printed in the
.out file. Default = 1 (Integer) |
| Mi | Mach numbers. (0.0 ≤ Real < 1.0) |
- The DIVERG entry should be selected with the Case Control command DIVERG.
- The first NROOT number of Dynamic pressures are printed for Divergence analysis in the .out file. If the number of dynamic pressures are lower than NROOT, then all of them are printed.
- Intermittent blank Mi fields are not allowed and a particular Mi value should not be repeated.
