DOPTPRM, DELSIZ
Bulk Data Entry The initial fractional move limit for size design variables.
| Parameter | Values | Description |
| DELSIZ | Real > 0 Default = 0.5 |
Only the initial value of
the move limits can be set. Move limits are automatically adjusted
to enhance iterative stability and convergence speed. The move limits for subsequent iterations may not be greater than this initial move limit. |
