DOPTPRM, POROSITY
Bulk Data Entry Controls the amount of intermediate densities in the model in the first phase of the Lattice Structure Optimization run.
| Parameter | Values | Description |
| POROSITY | < HIGH, MED, LOW > | Controls the amount of
Lattice Structure Optimization run. For lattice cells the
homogenized Young's modulus to density relationship is approximated
as E = ρPE0, where E0 denotes Young's modulus of the
dense material and P is the penalty value. Varying levels of
lattice/porous domains in topology results are controlled by the
parameter POROSITY which adjusts the penalty (P).
