DREPORT
Bulk Data Entry Used in the Bulk Data section to report responses, defined by DRESP1, DRESP2 and DRESP3 cards, to the output file, which are not constrained or used as the objective function, as defined by the optimization problem.
| DREPORT | DRID | RID | LALLOW | UALLOW | NL | NU |
| DREPORT | 1 | 1 | 1.0 | 5.0 | 2 | 5 |
Associated Cards
| DRESP1 | 1 | TOPN | DISP | 3 | 4668 |
| DRID | Report identification
number. (Integer > 0) |
| RID | DRESP1,
DRESP2, or DRESP3
identification number. (Integer > 0) |
| LALLOW | Optional lower bound on
response for reporting purposes. (Real or blank) |
| UALLOW | Optional upper bound on
| NL | Optional number of lowest
responses to report.
(Integer or blank) |
| NU | Optional number of highest
response to report.
