DSYSID
Bulk Data Entry Defines responses and their target values for a system identification problem.
| DSYSID | DOID | LABEL | RID1 | SID1 | T1 /TID1 |
W1 /WTID1 |
| + | RID2 | SID2 | T2 /TID2 |
W2 /WTID2 |
| + | etc | ||||||||
| + | RIDi | SIDi | Ti /TIDi |
Wi /WTIDi |
| DSYSID | 22 | SYS | 3 | 4 | 0.002 | ||||
| + | 5 | 5 | 0.05 |
Associated Cards
| DRESP1 | 3 | TZ488 | DISP | 3 | 488 | ||||
| DRESP1 | 5 | TZ601 | DISP | 3 | 601 |
| DOID | Design objective
identification number. (Integer > 0) |
| LABEL | User-defined name for the
response. No default (Character) |
| RIDi | DRESP1,
DRESP2, or DRESP3
| SIDi | Subcase identification
number.
(Integer > 0) |
| Ti/TIDi | Target value or table
identification number of a TABLEDi entry that
specifies the target value as function of a loading frequency. No default (Real or Integer) |
| Wi/WTIDi | Weighting factor or table
specifies the weighting factor as function of a loading
frequency. Default = 1.0 (Real, Integer or blank) |
- If the DSYSID entry is
referenced by a DESOBJ Subcase entry, a
least squares objective function is used in the optimization. The objective
function is the sum of the squared, weighted, normalized differences between the
target responses and those calculated by the finite element
analysis:If the DSYSID entry is referenced by a MINMAX or MAXMIN Subcase Information Entry, the beta method is applied in the optimization as:
- DSYSID entries must have unique identification numbers with respect to DRESP1, DRESP2, and DRESP3 entries.
- DRESP1, DRESP2, and DRESP3 entries referenced by the DSYSID entry can define only a single response per subcase when the DESOBJ formulation is used. There is no such limitation with the MINMAX or MAXMIN formulations.
- In order to use DSCREEN to control the number of retained responses when performing a system identification, RTYPE=EQUA needs to be used on the DSCREEN entry.
