DVCREL1
Bulk Data Entry Relates Design Variables to Analysis Model Element Properties
Linearly relates a design variable to an analysis model element property using the equation:
| DVCREL1 | ID | TYPE | EID | EPNAME/ FID |
C0 | ||||
| DVID1 | COEF1 | DVID2 | COEF2 | etc. |
| ID | Relationship
identification number. ID must be unique with respect to other
DVCREL1 cards. No default (Integer > 0) |
| TYPE | Element type to be related
(DVCREL - Types) No default (Character) |
| EID | Element identification
number. No default (Integer > 0) |
| EPNAME/FID | Element property name,
such as "K" or "ZOFFS" (as in the documentation of the element Bulk
Data Entries), or field number on an element Bulk Data Entry. No default (Character or Integer > 0) |
| C0 | Constant in relationship
equation. Default = 0.0 (Real) |
| DVIDi | DESVAR
ID. No default (Integer > 0) |
| COEFi | Coefficient in
relationship equation. Default = 1.0 (Real) |
- This card is represented as an optimization design variable property relationship in HyperMesh.
