DVCREL2
Bulk Data Entry Relates design variables to an analysis model element property using a relationship defined by a DEQATN card. The equation inputs come from the referenced DESVAR values and constants defined on a DTABLE card.
| DVCREL2 | ID | TYPE | EID | EPNAME/ FID |
EQID | ||||
| DESVAR | DVID1 | DVID2 | DVID3 | DVID4 | DVID5 | DVID6 | DVID7 | ||
| DVID8 | DVID9 | etc. | |||||||
| DTABLE | LABL1 | LABL2 | LABL3 | LABL4 | LABL5 | LABL6 | LABL7 | ||
| LABL8 | etc. |
| ID | Relationship
identification number. ID must be unique with respect to other
DVCREL2 cards. No default (Integer > 0) |
| TYPE | Element type to be related
(DVCREL - Types) No default (Character) |
| EID | Element identification
number. No default (Integer > 0) |
| EPNAME/FID | Element property name,
such as "K" or "ZOFFS" (as in the documentation of the element Bulk
Data Entries), or field number on an element Bulk Data Entry. No default (Character or Integer > 0) |
| EQID | Equation ID of
DEQATN data. No default (Integer > 0) |
| DESVAR | Indicates DESVAR ID numbers follow. | |
| DVID# | DESVAR
ID. No default (Integer > 0) |
| DTABLE | Indicates DTABLE labels follow. | |
| LABL# | Constant label. Must match
with a constant label of a DTABLE entry. No default (Character) |
- This card is represented as an optimization design variable property relationship in HyperMesh.
