DVMBRL1
Bulk Data Entry Linearly relates a design variable to properties of an MBD entity using the equation:
| DVMBRL1 | ID | TYPE | BID/ EID |
PNAME | C0 | ||||
| DVID1 | COEF1 | DVID2 | COEF2 | etc. |
Example 1
To relate the translational x component of stiffness value (K1) on a
CMBUSH whose ID is 22 to Design Variable 5.
| DVMBRL1 | 88 | CMBUSH | 22 | K1 | 0.0 | ||||
| 5 | 1.0 | ||||||||
| DESVAR | 5 | 5.00 | 1.50 | 9.90 |
Example 2
To relate the mass of a rigid boy whose ID is 3 to design variable 5.
| DVMBRL1 | 88 | PRBODY | 3 | M | 0.0 | ||||
| 5 | 1.0 | ||||||||
| ID | Response identity. ID must
be unique with respect to other DVMBRL1 and DVMBRL2 cards. No default (Integer > 0) |
| TYPE | MBD entity type to be
related. 1 No default (Character) |
| BID/EID | Body ID or Element ID
number. When TYPE is PRBODY,
this field is the ID number of a rigid body. When
TYPE is CMBUSH(M),
CMBEAM(M), or CMSPDP(m), this
field is the ID number of a corresponding element. No default (Integer > 0) |
| PNAME | Property name, such as "A"
or "L" (as in the documentation of the PRBODY,
CMBEAM(M), CMBUSH(M), and
CMSPDP(M) cards). No default (Character or Integer > 0) |
| C0 | Constant in relationship
equation. Default = 0.0 (Real) |
| DVIDi | DESVAR
ID. No default (Integer > 0) |
| COEFi | Coefficient in
relationship equation. Default = 1.0 (Real) |
- MBD entity type information:
- PRBODY
- IXX
- IYY
- IZZ
- IXY
- IXZ
- X
- X component of center of gravity.
- Y
- Y component of center of gravity.
- Z
- Z component of center of gravity.
- CMBEAM/CMBEAMM
- L
- Undeformed length along the X-axis of the beam.
- A
- Area of the beam cross-section.
- I1
- Area moment of inertia in plane 1 about the neutral axis.
- I2
- J
- Torsional constant.
- K ~ K
- Area factor for shear.
- CMBUSH/CMBUSHM
- K ~ K
- Translational stiffness.
- K ~ K
- Rotational stiffness.
- B ~ B
- Translational damping.
- B ~ B
- Rotational damping.
- P ~ P3
- Translational preload.
- P4 ~ P6
- Rotational preload.
- CMSPDP/CMSPDPM
- K
- Stiffness
- B
- Damping
- L
- Unstretched length of spring damper.
- PF
- Preload force.
- This card is represented as an optimization design variable property relationship in HyperMesh.
