DVMREL1
Bulk Data Entry Linearly relates a design variable to an analysis model material property using the equation:
| DVMREL1 | ID | TYPE | MID | MPNAME/ FID |
C0 | ||||
| DVID1 | COEF1 | DVID2 | COEF2 | etc. |
Example 1
To relate the Damping Coefficient value on a MAT1 card (field 9)
to Design Variable 5.
| DVMREL1 | 17 | MAT1 | 22 | 9 | 0.0 | ||||
| 5 | 1.0 |
Example 2
This example is the same as Example 1, except that it defines MPNAME
in place of FID.
| DVMREL1 | 17 | MAT1 | 22 | GE | 0.0 | ||||
| 5 | 1.0 |
Associated Cards
| DESVAR | 5 | GE | 1.0 | 2.0 | 0.5 | ||||
| MAT1 | 22 | 2.1e5 | 0.3 | 7.85e-9 | 1.0 |
| ID | Relationship
identification number. ID must be unique with respect to other
DVMREL1 cards. No default (Integer > 0) |
| TYPE | Material type to be
related (MAT1, MAT2, MAT4, MAT5, MAT8, MAT9, or MAT9OR). No default (Character) |
| MID | Material identification
number. No default (Integer > 0) |
| MPNAME/FID | Material property name,
such as "E" or "RHO" (as in the documentation of the material Bulk
Data Entries), or field number on a material Bulk Data Entry. No default (Character or Integer > 0) |
| C0 | Constant in relationship
equation. Default = 0.0 (Real) |
| DVIDi | DESVAR
ID. No default (Integer > 0) |
| COEFi | Coefficient in
relationship equation. Default = 1.0 (Real) |
- See the DVMREL - Types section for details on the supported material fields and the MPNAME/FID entries.
