ESLTADD
Bulk Data Entry Defines a combined time step selection set as a union of selected time steps defined via ESLTIME entries for Geometric Nonlinear ESLM optimization or a Multibody Dynamics ESLM optimization.
| ESLTADD | SID | S1 | S2 | S3 | S4 | S5 | S6 | S7 | |
| S8 | S9 | etc. |
| ESLTADD | 101 | 9 | 11 | 13 |
| SID | Set identification
number. (Integer > 0) |
| Si | Set identification
numbers of time step selections defined via
ESLTIME Bulk Data Entries.
Si should be unique and may not be the
identification number of a set defined by another
ESLTADD entry. (Integer > 0) |
- ESLTADD can be selected within the Subcase Information section using the command ESLTIME=SID.
- ESLTADD entries take precedence over ESLTIME entries. If both entries have the same SID, only the ESLTADD entry will be used.
- This card is represented as a load collector in HyperMesh.
