FATDEF
Subcase Information Entry The FATDEF command can be used to select a FATDEF Bulk Data Entry that will define the elements, and their associated fatigue properties, to be considered for Fatigue Analysis.
FATDEF = option
| Argument | Options | Description |
| option | <SID> No default |
- FATDEF Bulk Data Entries will not be used unless selected in the Subcase Information section.
- If present above the first subcase, it is applied to all fatigue analysis subcases.
